Originally Posted By gregsdart
Probably the steel on steel (bearing to snap ring) doesn't play well? Very limited surface contact area, weak bearing cage and snap ring not designed to take the pounding I bet.
could these be saved by bushing them ? provided the bodies are not cracked. just a curious question. if so, why don't you see this done, and if not, why not ?
beer
