Re: MSD digital 6 with factory distributor
[Re: The Sphinx]
#2055798
04/16/16 11:02 PM
04/16/16 11:02 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
check the gap on the pickup coil?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: The Sphinx]
#2055821
04/16/16 11:37 PM
04/16/16 11:37 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
How much gap is there supposed to be? i got mine set at 8 thous.been workin good many years.
[Re: bonefish]
#2055915
04/17/16 01:24 AM
04/17/16 01:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
How much gap is there supposed to be? i got mine set at 8 thous.been workin good many years. .008 is spec... if it sparks jumping the box side of the dist then your pick up is bad(if your gap is even in the ball park) EDIT Make sure the carbon ball is in the center of the cap and you have the rotor in there(been there)
[Re: The Sphinx]
#2056059
04/17/16 12:27 PM
04/17/16 12:27 PM
MR_P_BODY
Was this car running before... or is this a new build.. do you have both the run and crank wires jumped together out of the ignition switch so it has power during cranking and run
[Re: justinp61]
#2056108
04/17/16 01:38 PM
04/17/16 01:38 PM
MR_P_BODY
Have you tried to start it by jumpering the starter relay? Thats a good way to test the ignition switch to see if both wires are connected together.. since its in the run position
[Re: The Sphinx]
#2056235
04/17/16 04:55 PM
04/17/16 04:55 PM
MR_P_BODY
Switch is good, 12v incomming is good, 12v(thick) red is good. It acts like im not signaling thru the distributor pick up. With the test you did(jumping the box side of the dist) thats what the test says also... I just went through this last week.. but when I jumped the box side it had a spark at the coil lead just 1 time then nothing.. my coil was shot... after changing the coil.. it runs better than it ever has
[Re: The Sphinx]
#2056247
04/17/16 05:27 PM
04/17/16 05:27 PM
Posts: 916 SE Washington
Forest
SE Washington
Switch is good, 12v incomming is good, 12v(thick) red is good. It acts like im not signaling thru the distributor pick up. I would just double check that the keyed 12 volts to the MSD stays hot while the engine is cranking...
[Re: Forest]
#2056255
04/17/16 05:39 PM
04/17/16 05:39 PM
Posts: 591 Champion City
The Sphinx
Champion City
Switch is good, 12v incomming is good, 12v(thick) red is good. It acts like im not signaling thru the distributor pick up. I would just double check that the keyed 12 volts to the MSD stays hot while the engine is cranking... I did, 12v when I'm cranking
[Re: MR_P_BODY]
#2056260
04/17/16 05:42 PM
04/17/16 05:42 PM
The Sphinx
Champion City
Switch is good, 12v incomming is good, 12v(thick) red is good. It acts like im not signaling thru the distributor pick up. With the test you did(jumping the box side of the dist) thats what the test says also... I just went through this last week.. but when I jumped the box side it had a spark at the coil lead just 1 time then nothing.. my coil was shot... after changing the coil.. it runs better than it ever has I swapped out a blaster ss and tried blaster 2, no luck. I went through the troubleshooting guide that came with it and also their website. I ohmed out the distributor and got .287 on the 2k scale.
[Re: The Sphinx]
#2056274
04/17/16 06:09 PM
04/17/16 06:09 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Hmmm. Seems like you checked everything. Box is probably done.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: The Sphinx]
#2056279
04/17/16 06:14 PM
04/17/16 06:14 PM
DARTH V8Я
Its a TRAP!
Had a brand new MSD box that didn't even make it out of the gate.
[Re: The Sphinx]
#2056442
04/17/16 11:22 PM
04/17/16 11:22 PM
Posts: 430 Michigan
HR3128
Only when I jumper the violet and green wires from the box side. So The coil fires when you jump the violet & green wire. That proves your wiring & box are good. Next step is to verify the distributor will trigger the box. Set-up the same test but leave the distributor violet & green wires connected. Pull the dist cap & rotor. Loosen the distributor hold-down so that you can turn the housing. Then rotate the housing so that the pick-up coil moves across one of the teeth on the trigger wheel. The MSD should fire the coil every time the pick-up moves across the trigger wheel. If you position the dis pick-up & trigger wheel properly, you might be able to use the distributor advance to move the trigger back & forth across the pick-up. Coil should fire every time you do this.
[Re: The Sphinx]
#2058309
04/20/16 12:16 PM
04/20/16 12:16 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Sounds like the pick up coil in the distributor was bad. I ran my car for years with an OE distributor and a digital 6 box.
[Re: The Sphinx]
#2058576
04/20/16 07:08 PM
04/20/16 07:08 PM
MR_P_BODY
But that distributor worked excellent in my other car. As its back in there and running. Dont know what to tell you.. I never ran a digital 6 but have run plenty of stock dist with 6al and 7al boxes.. both lean burn and dist with timing... so I would think that the digital box doesnt like something about that dist.. might be the difference in the resistance
