Re: Hemi rotating assemblyl
[Re: Lost in life]
#2054690
04/15/16 12:16 AM
04/15/16 12:16 AM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Hemi piston, stock stroke 6.86 rod. Add 3/8 to stroke and 1/4 rod length, can't see now way to stay out of oil ring, am I missing something here.
[Re: cudaman1969]
#2054795
04/15/16 08:38 AM
04/15/16 08:38 AM
Posts: 2,687 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
These are 572 Diamond Pistons that I got from Ray Barton for 7.10" rods.
2011 Drag Pak Challenger
[Re: Lost in life]
#2054798
04/15/16 08:51 AM
04/15/16 08:51 AM
rickseeman
Stuttgart, Arkansas
So if I put together a 540 with mopar heads,10.5 compression and a cross ram/ with a hydraulic cam what approximate horsepower can I expect? Would like to have car run high 10's if possible. Ray prefers the 528. We put a flat tappet 572 in a 3550 lb 70 Cuda (former Super Stocker so it knew how to hook up and go) and went high 9's. That was a drag car with slicks and 5000 converter. Modern flat tappet, single 4 bbl, 528/540/572 engines, done well, make over 800 hp.
[Re: Lost in life]
#2054824
04/15/16 10:34 AM
04/15/16 10:34 AM
rickseeman
Stuttgart, Arkansas
Sorry, I'm not following what you are saying. Put what 2 side by side? But, compression height on a hemi piston is not to the top of the piston.
[Re: Lost in life]
#2054841
04/15/16 10:55 AM
04/15/16 10:55 AM
Posts: 315 Northeast Indiana
73DAD
Northeast Indiana
Nevermind Rick, I figured it out. The "perspective" wasn't turned on the stupid software. Operator error! They would have looked identical except for the dome not modeled on top. deleted the post.
