Re: Hemi rotating assemblyl [Re: Lost in life] #2054632
04/14/16 10:58 PM
04/14/16 10:58 PM
AndyF Offline
AndyF  Offline
I'd highly recommend the 4.25 stroke. That combination basically falls together and then you plenty of clearance for the windage tray and the internal oil pickup. Just buy a high quality 4.25 stroke crank with 2.200 rod journals and get a set of good 7.100 long BB Chevy rods and you're good to go. Most anyone should be able to make pistons for that combo, might even be a shelf piston at JE or Diamond.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054685
04/15/16 12:11 AM
04/15/16 12:11 AM
Everywhere
Lost in life Offline OP
Everywhere
So if I put together a 540 with mopar heads,10.5 compression and a cross ram/ with a hydraulic cam what approximate horsepower can I expect? Would like to have car run high 10's if possible.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054686
04/15/16 12:12 AM
04/15/16 12:12 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Hemi piston 4.5 stoke 7.045 rod
Hemi piston
Re: Hemi rotating assemblyl [Re: Lost in life] #2054688
04/15/16 12:13 AM
04/15/16 12:13 AM
fredericksburg,va
fredericksburg,va
440 piston stock stroke 6.76 rod. Plenty of room to go up on this piston
Re: Hemi rotating assemblyl [Re: Lost in life] #2054690
04/15/16 12:16 AM
04/15/16 12:16 AM
fredericksburg,va
fredericksburg,va
Hemi piston, stock stroke 6.86 rod. Add 3/8 to stroke and 1/4 rod length, can't see now way to stay out of oil ring, am I missing something here.
Re: Hemi rotating assemblyl [Re: cudaman1969] #2054795
04/15/16 08:38 AM
04/15/16 08:38 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
These are 572 Diamond Pistons that I got from Ray Barton for 7.10" rods.
2011 Drag Pak Challenger
Re: Hemi rotating assemblyl [Re: rickseeman] #2054797
04/15/16 08:41 AM
04/15/16 08:41 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Piston info
Re: Hemi rotating assemblyl [Re: Lost in life] #2054798
04/15/16 08:51 AM
04/15/16 08:51 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Ray prefers the 528. We put a flat tappet 572 in a 3550 lb 70 Cuda (former Super Stocker so it knew how to hook up and go) and went high 9's. That was a drag car with slicks and 5000 converter. Modern flat tappet, single 4 bbl, 528/540/572 engines, done well, make over 800 hp.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054824
04/15/16 10:34 AM
04/15/16 10:34 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Sorry, I'm not following what you are saying. Put what 2 side by side? But, compression height on a hemi piston is not to the top of the piston.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054841
04/15/16 10:55 AM
04/15/16 10:55 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Nevermind Rick, I figured it out. The "perspective" wasn't turned on the stupid software. Operator error! They would have looked identical except for the dome not modeled on top. deleted the post.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054844
04/15/16 10:57 AM
04/15/16 10:57 AM
fredericksburg,va
fredericksburg,va
I will add, my piston was for a standard deck height with 7.1 rod. My deck being down .130 I found a 7.045 rod, still a little tall but I'll take it up with a thicker head gasket.
Re: Hemi rotating assemblyl [Re: Lost in life] #2054879
04/15/16 11:51 AM
04/15/16 11:51 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Modern pistons have.990" pins and much smaller ring stacks. That helps this all fit together.
Re: Hemi rotating assemblyl [Re: Lost in life] #2055005
04/15/16 03:57 PM
04/15/16 03:57 PM
Everywhere
Everywhere
Thank you all for your input. I will start gathering parts for the build. Most likely will go with the 540. I will check with Barton and Tim for rotating assemblies before doing anything. Appreciate your replies.
