Re: motor plate water pump gasket problems
[Re: 440Jim]
#2052614
04/12/16 09:52 AM
04/12/16 09:52 AM
Posts: 2,567 S.E. Michigan
cl440
S.E. Michigan
Although I had a one piece front plate, I found that after awhile (months) gaskets could leak. Then I just used only RTV (no gaskets) and it never leaked again. Same here. We have actually replaced most every gasket on our engine with RTV.
[Re: challengermike]
#2052618
04/12/16 10:12 AM
04/12/16 10:12 AM
Posts: 9,896 MI, usa
dvw
MI, usa
Never had a leak (1 piece plate) when sealed with Hylomar. And there is no cure time. Is that like the stuff gm use's on the front diff case half and t case half ? There's is red though. No that is aenerobic sealer. Poor in shear, very brittle when it cures. Works great for a small gap surface. Doug
#2052620
04/12/16 10:17 AM
04/12/16 10:17 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
I just use ultra grey silicone, no gaskets. No leaks in 10 years.
#2052783
04/12/16 02:40 PM
04/12/16 02:40 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Years ago I ran the 2 piece ear mounts, flex would break the seal and it would start to leak. I welded a strap across the top of the ears and that stopped the flex and the leak problem. Now I have AndyF front motor mounts on 2 of my cars, I just use standard water pump gaskets and never have had a leak. I do put stress on them from torque to pounding the oil pan into the pavement.
