Page 4 of 4 1 2 3 4
Re: Lighter wheels [Re: Mebsuta] #2066770
05/03/16 10:04 PM
05/03/16 10:04 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Anyone that has spent time in their car at the drag strip will know how much of a difference the wheel/tire weight makes.
Re: Lighter wheels [Re: Mebsuta] #2066803
05/03/16 10:33 PM
05/03/16 10:33 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
True.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Lighter wheels [Re: 360view] #2066927
05/04/16 01:42 AM
05/04/16 01:42 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Originally Posted By 360view
Those tests of aluminum versus carbon fiber wheels are interesting, particularly the coast down.
In the Bosch Automotive handbook they give the equations for finding tire rolling resistance and aerodynamic Cd by coasting down from 60 mph.
Others have written that it is better to find these two values by coasting down two different grade hills at "terminal velocity"
because this is a steady speed test,
And rotating mass like wheels, driveshafts, gears, etc,
cannot add or subtract flywheel rotational energy
to skew the measurements.
The Car&Driver tests show that 20 lbs of wheel weight can indeed be measured by common stopwatch or ruler.
I've got a similar set of equations and spreadsheets. Stuff varying from how much horsepower it takes to drive a vehicle at X speed, Y grade, and Z size. I've also got the set of equations for a similar test that you measured by doing a coast down test.
Re: Lighter wheels [Re: Mebsuta] #2067036
05/04/16 10:39 AM
05/04/16 10:39 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Re: Lighter wheels [Re: MuuMuu101] #2067060
05/04/16 11:37 AM
05/04/16 11:37 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"I've also got the set of equations for a similar test that you measured by doing a coast down test."
The thinking being a longer coast down result is from a wheel that stores more energy, correct?
Wonder if in that test, wheel "fan" energy is a factor when 4 alike wheels are used? work
Page 4 of 4 1 2 3 4
