Page 24 of 45 1 2 22 23 24 25 26 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2050475
04/09/16 04:34 PM
04/09/16 04:34 PM
AndyF Offline
AndyF  Offline
No, I didn't think about that until too late. I didn't take the adapter with me. My guess is that the Dominator on an adapter would've pushed the TF intake up another 10 hp or so.
Re: Trick Flow heads [Re: fast68plymouth] #2050477
04/09/16 04:39 PM
04/09/16 04:39 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Is that 1050/4150 one that has the baseplate that will fit either 4150 or 4500 manifolds?
If so, did you try it on the other intake?
Re: Trick Flow heads [Re: AndyF] #2050482
04/09/16 04:47 PM
04/09/16 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By AndyF
The porting that Wilson did on my M1 intake picked up 30 hp. Engine made 715 hp this morning using the same 1050 Dominator that I was running before. Gasket match still isn't perfect so there is probably a little more power hiding in the combo.
I like the valve covers Andy up
wave
Re: Trick Flow heads [Re: fast68plymouth] #2050522
04/09/16 06:05 PM
04/09/16 06:05 PM
AndyF Offline
AndyF  Offline
yes, the QF carb will bolt to either a 4150 or 4500 intake but it doesn't exactly work on a 4500 intake without some other fixes so I didn't run it that way. That would be a good thing to test at some point.
Re: Trick Flow heads [Re: MR_P_BODY] #2050524
04/09/16 06:07 PM
04/09/16 06:07 PM
AndyF Offline
AndyF  Offline
wave
That is my "topless valve cover"! It works pretty well. This engine has a well sorted out valve train so there isn't a lot of oil spraying around. Just 8 streaks of oil on the valve cover. Each rocker arm sprays a small streak of oil on the lid from the roller wheel.
Re: Trick Flow heads [Re: AndyF] #2050559
04/09/16 06:58 PM
04/09/16 06:58 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Look's like I have just settled on which intake that I am going to use on my 512, thanks for the time and effort Andy, I have been waiting on this info to help me make up my mind, wish TF made the low deck manifold with the dominator flange, but it looks like I will use my existing 2" spacer and do a little blending. thumbs
Re: Trick Flow heads [Re: fast68plymouth] #2050602
04/09/16 08:25 PM
04/09/16 08:25 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Did the gap from max torq & max Hp open up at all? Last I seen back in this thread was like only 600 rpm apart iirc.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Trick Flow heads [Re: dartman366] #2050625
04/09/16 09:41 PM
04/09/16 09:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you want the most from the adapter, I`d deep blend it into and shape the upper most part of the intake cos the results are awesome..........
Re: Trick Flow heads [Re: Thumperdart] #2050677
04/09/16 11:03 PM
04/09/16 11:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thats exactly my plan. up
Re: Trick Flow heads [Re: dartman366] #2050766
04/10/16 01:46 AM
04/10/16 01:46 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs
Re: Trick Flow heads [Re: AndyF] #2050850
04/10/16 04:42 AM
04/10/16 04:42 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I would like to see a video of that in action.
1974 Roadrunner
1967 Charger
Re: Trick Flow heads [Re: fast68plymouth] #2051380
04/10/16 10:26 PM
04/10/16 10:26 PM
Nevada
U
uber-fast Offline
uber-fast  Offline
U
Nevada
To bad you didn't have a M1 tunnel ram to try. Would have be interesting results twocents
Re: Trick Flow heads [Re: fast68plymouth] #2051476
04/10/16 11:52 PM
04/10/16 11:52 PM
AndyF Offline
AndyF  Offline
I'd like to try a tunnel ram but didn't have any luck finding one. I posted a parts wanted ad but never got any response.
Re: Trick Flow heads [Re: fast68plymouth] #2051774
04/11/16 12:50 PM
04/11/16 12:50 PM
AndyF Offline
AndyF  Offline
I needed one of my AR372 plates to run the QF 1050 on the Wilson intake but I forgot to take one with me. If you bolt the 4150 carb directly to the M1 intake the linkage hits the manifold. There is also sometimes a leak since the 4150 baseplate doesn't always cover the opening in the 4500 intake.
Re: Trick Flow heads [Re: fast68plymouth] #2052152
04/11/16 09:08 PM
04/11/16 09:08 PM
In a house near you
Street Monkies Offline
In a house near you
Andy let me know if you plan on selling the trick flow intake. I had cash the last time I messaged you about parts. Thanks
Re: Trick Flow heads [Re: Street Monkies] #2052237
04/11/16 10:23 PM
04/11/16 10:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Does Wilson do port work on other brands of manifolds as well?
Re: Trick Flow heads [Re: GY3] #2052276
04/11/16 10:51 PM
04/11/16 10:51 PM
AndyF Offline
AndyF  Offline
I'm pretty sure that if you have the money they'll port whatever your drag in the door. Check out the cool stuff on their website: http://www.wilsonmanifolds.com/
Re: Trick Flow heads [Re: Street Monkies] #2052283
04/11/16 10:53 PM
04/11/16 10:53 PM
AndyF Offline
AndyF  Offline
I don't think I'll sell this Trick Flow intake anytime soon. I might be willing to make you a good deal on a very slightly used Victor 383 though.
Re: Trick Flow heads [Re: AndyF] #2052837
04/12/16 03:27 PM
04/12/16 03:27 PM
Jamie McGrath Offline
Here is an outside shot of a stock intake and then the second picture shows the outside of the ported intake. It appears that Wilson welded up the outside so they could open up the ports. The stock intake has almost an inch between the center runners while the Wilson intake has a V between the runners.
Andy, I was waiting for someone else too ask and seeing as no one has, I will. What was the stock M1 intake volume compared too the reworked Wilson M1 intake volume? Just wondering as it really picked up after reworking it looks huge inside but it must also be moving plenty of air pretty fast.
Did they give you some type of flow sheet?
Re: Trick Flow heads [Re: fast68plymouth] #2052918
04/12/16 05:27 PM
04/12/16 05:27 PM
AndyF Offline
AndyF  Offline
I haven't compared intake runner volumes. I have a stock M1 intake here so I'll give that a try. Might be interesting to see the volume difference if I can figure out a way to measure it accurately.
No flow sheet with the intake, never thought to ask them for one. I don't know if they flow them after porting or not.
