Re: 727 Leaking !! [Re: okie] #2051212
04/10/16 06:41 PM
04/10/16 06:41 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Great Pictures !!
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 727 Leaking !! [Re: okie] #2051709
04/11/16 10:39 AM
04/11/16 10:39 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Is it just the one seal? There's not one on the center rod ? I"m going to see if I can get what I need today. Thanks Ronnie
Re: 727 Leaking !! [Re: okie] #2051829
04/11/16 01:51 PM
04/11/16 01:51 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes there is a seal in the center , that one is a little harder to replace in the car but it can be done, but that seal is above the full level so it should not cause the bad leak you say you have.
Re: 727 Leaking !! [Re: okie] #2051953
04/11/16 04:34 PM
04/11/16 04:34 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Yes.
Will leak when the torque converter drains back.
Re: 727 Leaking !! [Re: okie] #2053499
04/13/16 10:27 AM
04/13/16 10:27 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I got the tool on the way and picked up my big seal, any body know a number on the small seal Thanks
Re: 727 Leaking !! [Re: okie] #2053546
04/13/16 11:38 AM
04/13/16 11:38 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Napa # ATP13308 is the part number for the throttle pressure shaft seal.
Re: 727 Leaking !! [Re: mopowers] #2053792
04/13/16 06:44 PM
04/13/16 06:44 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Can I change this one with the tranny still in the car like the big one
Re: 727 Leaking !! [Re: okie] #2053797
04/13/16 06:54 PM
04/13/16 06:54 PM
IMGTX Offline
IMGTX  Offline
There is a small snap ring that holds the two shafts together on top. Remove it then the seal. The problem is that when you remove it, it will want to let the shaft fall down into the case and the pan may need to come off.
IIRC but it's been a little while
