Page 5 of 10 1 2 3 4 5 6 7 9 10
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2042250
03/30/16 09:14 PM
03/30/16 09:14 PM
Lee Co. Fla.
5carguy Online content
5carguy  Online Content
Lee Co. Fla.
iagree Beautiful work.
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2042425
03/31/16 01:08 AM
03/31/16 01:08 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
The attention to detail is amazing! Its gonna be a stunner when finished.
Looking at your window sticker, is your SPD on the fender tag 802? Super early production car.
Re: factory six pack shaker 1971 challenger total restoration [Re: NV69B7RR] #2042538
03/31/16 09:36 AM
03/31/16 09:36 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
I think it might be B02 (November 2, 1970). There are more than a few 802 SPD cars kicking around but the VINs are all 1001xx. And there are at least 2 shaker Challenger ragtops within that batch.
Re: factory six pack shaker 1971 challenger total restoration [Re: YYZ] #2044701
04/02/16 08:55 PM
04/02/16 08:55 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline OP
ek3  Offline OP
E
factory door sticker is 10/70... FWIW.. one thing I remember was that it took 11 weeks from the date the order was placed to take delivery of the car. ALSO ON THE BOTTOM IS 10-27 B 80 ?
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2048793
04/07/16 12:52 PM
04/07/16 12:52 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Mine is 10/70 as well - following your build
I'm also curious of the C-pillar treatment. I'd like a good option for mine which is cracking at the rear 1/4 windows
Re: factory six pack shaker 1971 challenger total restoration [Re: wally426ci] #2049210
04/07/16 09:13 PM
04/07/16 09:13 PM
E
ek3 Offline OP
ek3  Offline OP
E
I like the solid seam. as I understand it , the flex in the car is the main cause of cracking at the seams . if you get the welds through out the car done solid, it should make it less prone to cracking. I got a few shots of the trim ring with the common broken bolts issue . the guys fixed it by drilling it out - taping the ring , then installed the bolt using panel bond on the bolt threads ! the top can be finished off for paint and it is a solid repair !!
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2049214
04/07/16 09:16 PM
04/07/16 09:16 PM
E
ek3 Offline OP
ek3  Offline OP
E
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2049216
04/07/16 09:17 PM
04/07/16 09:17 PM
E
ek3 Offline OP
ek3  Offline OP
E
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2049223
04/07/16 09:21 PM
04/07/16 09:21 PM
E
ek3 Offline OP
ek3  Offline OP
E
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2050239
04/09/16 09:58 AM
04/09/16 09:58 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Thanks for showing the trim ring stud repair details! I assume you use body filler on the top side of the stud?
Are the original studs cast as part of the ring or where the studs inserted into the ring as it was cast? Mine has a few broken studs.
Re: factory six pack shaker 1971 challenger total restoration [Re: larry4406] #2050614
04/09/16 08:55 PM
04/09/16 08:55 PM
E
ek3 Offline OP
ek3  Offline OP
E
**** They are cast as part of the ring. The top is finished with an epoxy steel and /or filler can be used.. Very little is left to fill on the ring ! what is on the top in the photo is panel bond from the installation of the bolt.
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2050878
04/10/16 09:37 AM
04/10/16 09:37 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I just saw your thread for the first time. That's going to be a stunning Challenger when completed. Are going to paint the car BC/CC or go with a single stage? I'm leaning to a single stage on my build to try and look as close to day one as possible.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2055352
04/16/16 02:11 AM
04/16/16 02:11 AM
E
ek3 Offline OP
ek3  Offline OP
E
I am going to let elite customs do it with what ever they decide . most likely a base/clear . they -may- have painted as many mopars as the factory did by now !! sometimes there are just to many choices and I figure it is hard to beat a man at his game ....
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2059326
04/21/16 10:34 PM
04/21/16 10:34 PM
E
ek3 Offline OP
ek3  Offline OP
E
final guide coat priming...
final guide prime 1.jpgfinal guide prime 2.jpgfinal guide prime 3.jpgfinal guide prime 4.jpg
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2059327
04/21/16 10:35 PM
04/21/16 10:35 PM
E
ek3 Offline OP
ek3  Offline OP
E
and this ..
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2059860
04/22/16 06:28 PM
04/22/16 06:28 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Very Nice.
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2061894
04/26/16 09:20 AM
04/26/16 09:20 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Awesome build, man that is a lot of sheetmetal to replace, car is going to be a thing of beauty!!
Re: factory six pack shaker 1971 challenger total restoration [Re: Gavin] #2064338
04/29/16 10:41 PM
04/29/16 10:41 PM
E
ek3 Offline OP
ek3  Offline OP
E
some final pimer pics..
final prime  side shot.jpgfinal prime pre paint.jpgfinal primer side shots.jpgfinal guide prime 4.jpg
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2071176
05/11/16 12:12 AM
05/11/16 12:12 AM
E
ek3 Offline OP
ek3  Offline OP
E
and now a few finish paint shots..
Re: factory six pack shaker 1971 challenger total restoration [Re: ek3] #2071177
05/11/16 12:13 AM
05/11/16 12:13 AM
E
ek3 Offline OP
ek3  Offline OP
E
and ..
