Re: Lighter wheels
[Re: Mebsuta]
#2050146
04/09/16 01:39 AM
04/09/16 01:39 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
It's unsprung weight the hardest to lose and the most benificial. The car should stop accelerate and handle better, what that looks like on a spreadsheet is individual to the particular car. I'm unaware of a formula to calculate what gains to expect but with your car as a baseline back to back test will net you the results. Can your backside tell? I have no idea. But 36lbs of unsprung is significant
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Lighter wheels
[Re: Mebsuta]
#2050213
04/09/16 08:27 AM
04/09/16 08:27 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Its unsprung AND rotating weight... win and win. Thats weight at the very end ov the powertrain that your engine has to spin. A heavier axle costs performance, a heavier driveshaft costs performance, you dont think 8 extra pounds a wheel... spinning at a far greater diameter (thus speed), demanding far greater torsional strength is not going to cost performance? And a reason why so many teams dont go nuts on re-sciencing the rollers is because its largely been done already. Light wheels and tires are readily available, and more reasonable in price than years back. To get beyond what you see out there requires an investment far beyond return. Also, some stock car stuff is as light as its allowed to be, or as light as it CAN be. Far more stress on that NASCAR wheel than a local roundy-round wheel, or the street. You can buy 19lb circle track wheels, but the actual NASCAR ones are far heavier i believe.
If strength did not matter, we'd all be running those ugly ol' Weld Drag Stars...
Re: Lighter wheels
[Re: moparx]
#2050290
04/09/16 11:12 AM
04/09/16 11:12 AM
Posts: 23,295 Here
jcc
Here
I would think 8-9lbs per wheel in rotating weight would be noticeable, and especially on the CF angle. I always wondered why city buses don't have Alum wheels (6?), since they start and stop nearly every block, for their entire life cycle and alum wheels them saves 40+? lbs per wheel, but fire trucks have them and they maybe move twice a day?
fire trucks have aluminum wheels because firemen like them shiny [not that there is anything wrong with that]. city buses have steel wheels because they run into, and over, all kinds of stuff that would trash aluminum wheels in quick order. plus, i believe steel wheels are cheaper than aluminum and don't require constant polishing that will save the city big bucks in their yearly budget. garbage trucks are steel wheels for the same reason and i would hazard to guess they start and stop way more frequently than city buses. 1. Any CDL driver that has any record of running over stuff on any regular basis would promptly be dismissed/transferred, and if indeed that was the case, a $400? tire plus labor would be the first casualty, and I don't think the record would support that thesis. 2. Class 8 OTR and others have a long history with billions? of miles and alum wheels have no greater known failure rate then steel ( they are forged 2024 aircraft alum). 3. Alum wheels don't require any polishing, don't require any rust protection, and are fine with only the normal wash cycle maintenance. 4. The taxpayer who subsidizes the city buses on their fuel guzzling, every block starting and stopping, would be very rewarded in the 200?lb rotating weight reduction, both in fuel and brake tire wear costs on each vehicle, if the city buses swapped their steel wheels with the over budgeted first responder fire departments, and let the fire depart when not fighting fires, visit the bus depot and polish their new alum wheels. Edit, went to check my sources, looks like Alcoa, a leader in alum truck wheels has changed over Aircraft 2024 to 6061 forged wheels, likely for cost and better corrosion resistance, not sure it matters much, as the track record is still solid.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Lighter wheels
[Re: forphorty]
#2050291
04/09/16 11:13 AM
04/09/16 11:13 AM
DaytonaTurbo
Manitoba, Canada
It's works the same no matter where the weight comes from. Incorrect. Rotating weight has a greater effect. And the farther the weight from the axis, the greater the effect. In theory, yes. However I have yet to hear real-world results from one person who claimed to see gains in the 1/4 mile that were anything more than the result of losing the equivalent amount of weight from anywhere else in the car.
Re: Lighter wheels
[Re: moparx]
#2050322
04/09/16 11:46 AM
04/09/16 11:46 AM
Posts: 23,295 Here
jcc
Here
No I have long term daily experience seeing what you mentioned, my main point on wheel abuse, you would see and pay for tire repairs/replacement way before, and in much higher frequency then you would wheel damage driving caused abuse. The tires would be the Canary in the coal mine.
Re: Lighter wheels
[Re: BDW]
#2050361
04/09/16 12:57 PM
04/09/16 12:57 PM
Posts: 20,272 north of coder
moparx
i really didn't think i stated that it didn't matter. just "sometimes", for what ever reason, "somebody" decides that steel wheels are better to use than aluminum. take the post office for example. [please?] how many aluminum wheels you see on mail jeeps ? none here. fedX and UPS. all steel here at this hub and that includes the OTR rigs. no need to waste time and materials [paint and stripes on the outer rim edges] on alloy wheels, plus the savings on fuel. police and sheriff vehicles ? none around here, including the state police. lots of miles and fuel used, could use the extra money someplace else for sure. and as others have said, the time slips and "butt meters" show the same results with either in some instances. i'm not disputing or arguing for or against either. just observations. and to think i am accusing city bus drivers of running over everything and anybody is ludicrous. just not too many open man holes, tall curbs, street drains, curbs with street drains, etc. on the open roads. tires are certainly the "canary in the coal mine". and i can't run any more, plus i walk with a cane, so i'm not gonna put weights on and do a marathon.
Re: Lighter wheels
[Re: stumpy]
#2050369
04/09/16 01:12 PM
04/09/16 01:12 PM
Posts: 21,910 Kirkland, Washington
Pacnorthcuda
It's works the same no matter where the weight comes from. You couldn't be more wrong. Rotating weight is literally a flywheel. It has to be accelerated and decelerated in order for the car to perform. Totally different than static weight.
Re: Lighter wheels
[Re: stumpy]
#2050403
04/09/16 02:22 PM
04/09/16 02:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Seems real interesting most race teams try to remove body and chassis weight rather than lighter wheels and tires. If I was going to spend a pocket full of cash to make my street car faster it wouldn't be spent on wheels and tires which wouldn't produce near as much performance as some engine or trans upgrades for the same bucks. Really? The 4" skinnies they run for front tires ring a bell? Back tires are optimized for traction, maybe at the expense of possible weight savings. Of course your examples are straight line guys anyway, the only handling they care about is making the turn back to pit row. Anyone interested in handling and considering new rims would be smart to look at weights as well.
Re: Lighter wheels
[Re: moparx]
#2050507
04/09/16 05:37 PM
04/09/16 05:37 PM
Posts: 23,295 Here
jcc
Here
I hope the underlying point I was trying to make, wheel inertia matters little with constant speed, but anything that starts, and stops, especially frequently, consumes power accelerating (fuel/hp) and has to give the stored energy back up under braking (heat/brakes/tires). Thinking any municipalities can see the benefits of large Alum maintenance free wheels on high use vehicles, is obviously never going to happen in my lifetime, unless looking "shiney" becomes the in thing outside the fire dept. Our understanding of why is likely where we most differ.
Re: Lighter wheels
[Re: Mebsuta]
#2051398
04/10/16 10:47 PM
04/10/16 10:47 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
[ Moparts Family Site - Keep it Friendly ] does garbage and fire trucks have to do with this? So many outside variables.
The answer is lighter wheels have such a minor gain that most gains will go unnoticed but here is a fact, they will not hamper the performance. It brake better, turn better and for sure accelerate better.
I like the ankle weight example and here is another one for those who are not convinced. Jack your rear wheels off the ground. Remove the rear wheels and drums. Punch the throttle in neutral, punch it in gear and repeat with the drums and wheels on. The throttle response should be a great lesson for you.
Re: Lighter wheels
[Re: Magnum]
#2051575
04/11/16 01:51 AM
04/11/16 01:51 AM
Posts: 23,295 Here
jcc
Here
[ Moparts Family Site - Keep it Friendly ] does garbage and fire trucks have to do with this? So many outside variables. Maybe to help those with limited imagination envision a problem and/or a like solution? Care to share some of those "outside variables" that negate the correlation, if you can?
