Re: Lighter wheels
[Re: Mebsuta]
#2051606
04/11/16 02:27 AM
04/11/16 02:27 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Find lighter brake rotors, I am looking at the carbon fiber rotors, I can cut the weight in half on a rotor. Match this a lighter wheel and it might make a difference. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Lighter wheels
[Re: Mebsuta]
#2051642
04/11/16 04:50 AM
04/11/16 04:50 AM
Posts: 6,020 Salem
Grizzly
Moparts Proctologist
Salem
.............. If you have ever switched to lighter wheels, without making any other changes such as tire size or gears, did you notice any difference on the butt dyno?
I don't do any racing; just drive around on the street, but if lighter wheels would make it quicker and stop better, I would try them. Thanks. Yes. I took my heavy stock steel wheels off and put Weld Draglites on. The Welds were so light you could flip them around with one hand like they were cardboard. And, to answer your question, in my case it did not make a lick of difference in day to day use.
Mo' Farts
Moderated by "tbagger".
Re: Lighter wheels
[Re: Grizzly]
#2051657
04/11/16 07:23 AM
04/11/16 07:23 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
I don't do any racing; just drive around on the street, but if lighter wheels would make it quicker and stop better, I would try them. Thanks. Yes. I took my heavy stock steel wheels off and put Weld Draglites on. The Welds were so light you could flip them around with one hand like they were cardboard. And, to answer your question, in my case it did not make a lick of difference in day to day use. Damn. Maybe some ov us are just more sensitive than others... I went from 15x7" (28lbs) cop rims to 15x7" Weld Drag Stars (13lbs). Tires might have been +/- 1-2lbs, not much, dont even remember which way. The difference was drastic. So much so i drove on those Welds... against the advice ov many friends... until i bent two ov them. That was just in daily driving (hard driving... but no curbs or bumps). LIGHT rims... but flimsy as hell. Gonna go with 19lb 8"'s on my Challenger instead ov the 26lb 8" steelies and caps, and yeah, i expect it to make a noticeable difference. Another interesting anecdote... We swapped rollers on the girlfriend's 96GT from the stock 46lb 8" rims and 245's to cheapo (read solid, but HEAVY) E-bay 18x10's and 275/295's. They were 57/59lbs. The car slowed noticeably. Yes, the added width was worth a bit there i'm sure, but not all. The strangest thing was, that even now we had a nice open wheel... with LOTS ov airflow... we could not keep rotors on that car. In 4 years we went through 3 sets ov rotors... and the second set were 'the best' you can buy at the local shop. All that added grip really laid a taxin' on them poor little rotors. Did not expect that. My own 96GT (same stock rollers) never even got a brake job in the 3 years and 30K i owned it, and that was with much harder driving.
Re: Lighter wheels
[Re: Pale_Roader]
#2051768
04/11/16 12:42 PM
04/11/16 12:42 PM
Posts: 4,715 Wichita
GY3
Wichita
If your car is otherwise a total slug, then dont bother. But if its dialed in, then light rims/rollers improve EVERYTHING.
This makes zero sense. Some of you need a critical thinking class..
Re: Lighter wheels
[Re: jcc]
#2051845
04/11/16 02:12 PM
04/11/16 02:12 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
[ Moparts Family Site - Keep it Friendly ] does garbage and fire trucks have to do with this? So many outside variables. Maybe to help those with limited imagination envision a problem and/or a like solution? Care to share some of those "outside variables" that negate the correlation, if you can? Yes its good to bring examples and illustrations but we do not use deliver trucks as a template for making our cars perform better. Aluminum wheels on trucks may be there because the customer wants them, they are lighter, they look better or their budget says so. Trying to sound positive and I hope you recieve it this way.
Re: Lighter wheels
[Re: Magnum]
#2051919
04/11/16 03:43 PM
04/11/16 03:43 PM
Posts: 22,787 Bitopia
jcc
Bitopia
I will, but physics apply no matter what the end vehicle, plane, truck, car, lighter is better, etc, on this topic, no matter what the personal desires of the users or how they apply those desires.
Re: Lighter wheels
[Re: GY3]
#2052579
04/12/16 05:41 AM
04/12/16 05:41 AM
Pale_Roader
Swears too much
Swears too much
This makes zero sense. Some of you need a critical thinking class.. It makes perfect sense. So off you go.
Re: Lighter wheels
[Re: Mebsuta]
#2053115
04/12/16 10:07 PM
04/12/16 10:07 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Think I will try some sloot mags and see what happens.
68 Roadrunner. 383 4-spd. Beat up.
Re: Lighter wheels
[Re: Stanton]
#2053140
04/12/16 10:40 PM
04/12/16 10:40 PM
Posts: 7,547 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
So to the point of "rotating weight", this is more commonly referred to as "inertia" and would apply more to flywheels than to wheels and tires.
Yes, inertia is your enemy and you are proving the point: Tires and wheels are exactly like extra flywheels at each corner of the car - They are mass the engine has to keep accelerating throughout the whole run. Less mass is a faster car. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Lighter wheels
[Re: 67SATisfaction]
#2053150
04/12/16 10:51 PM
04/12/16 10:51 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Yes, inertia is your enemy and you are proving the point: Tires and wheels are exactly like extra flywheels at each corner of the car - They are mass the engine has to keep accelerating throughout the whole run. Less mass is a faster car. - Art I agree, as I stated earlier they are four flywheels. And not only does our vehicle have to accelerate them, it has to decelerate them too. And they located at the four corners, much worse than the actual "flywheel" which is extremely idealy located! Light wheels are a huge issue. The autocrossers know this!
Re: Lighter wheels
[Re: Mebsuta]
#2053210
04/12/16 11:31 PM
04/12/16 11:31 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A gyroscope would be a better analogy for wheels and tires. A gyroscope will resist ANY change in direction, that also includes acceleration in both the positive and negative direction. Less weigh means less gyroscopic effect https://woodgears.ca/physics/gyro.html
Re: Lighter wheels
[Re: stumpy]
#2053219
04/12/16 11:40 PM
04/12/16 11:40 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
It's works the same no matter where the weight comes from. Uhh, still no.
Re: Lighter wheels
[Re: Mebsuta]
#2053308
04/13/16 01:05 AM
04/13/16 01:05 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Think I will try some sloot mags and see what happens. Some of them can be quite heavy actually.. If you want to save weight, a forged aluminum wheel is going to be lighter than a cast one (especially an older slot mag that only has smallish windows with no material)
Re: Lighter wheels
[Re: OzHemi]
#2053454
04/13/16 09:10 AM
04/13/16 09:10 AM
Pale_Roader
Swears too much
Swears too much
Think I will try some sloot mags and see what happens. Some of them can be quite heavy actually.. If you want to save weight, a forged aluminum wheel is going to be lighter than a cast one (especially an older slot mag that only has smallish windows with no material) Just weigh them. Most ov those old-school slots were way light. I remember 18 and 19lb 15x8" rims. The old bias-ply 'performance' tires were lighter than radials too. Could make for a fairly aggressive weight loss where it counts. Almost worth using... All those old CAST aluminum rims were (in general) light. Now... i wont say they were strong... but they were light. You know how the saying goes... Modern forged is obviously badass. But damn... man, expensive.
Re: Lighter wheels
[Re: Mebsuta]
#2065517
05/01/16 10:00 PM
05/01/16 10:00 PM
Mebsuta
Khemi, Stygia
Okay, here is some unscientific data using my bathroom scale.
On the front, I went from Cragar Soft 8, 15x7, with 235/60/15 Futura GLS to the Summit 531 alloy, in 15x7 with the same 235/60/15 tire.
Cragar Soft 8, 15x7, with 235/60/15 Futura GLS weighed about 51 lbs.
Summit alloy, 15x7, with 235/60/15 Futura GLS weighs about 43 lbs.
Some other measurements with the bathroom scale:
Chrysler 15x7 police with 235/60/15 Futura GLS weighs about 50 lbs. Chrysler 15x7 police with 215/65/15 Cornell 1000 weighs about 45 lbs. Chrysler factory 15x7 steel with 235/60/15 Goodyear Eagle ST weighs about 45 lbs.
Don't take any of that as gospel, because those measurements were made on an analog bathroom scale.
Butt dyno test will probably be overnight sometime. If it works out, I will switch the 15x8 steelies in the back with alloy wheels.
Re: Lighter wheels
[Re: Mebsuta]
#2066357
05/03/16 03:41 AM
05/03/16 03:41 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I'm not going to lie, but I kind of find this thread a little funny. Yes, going to a lighter wheel should technically make your car faster. How much? It depends on what you have on there now vs what you plan on putting on. By decreasing weight, you're decreasing the amount of inertia required to rotate the wheel (i.e. less power to rotate). But in another sense you can also think of it as an aid to steering as now you have less mass to rotate side-to-side. If you want to have a fun math exercise and a very rough ballpark as to how much less energy is required to spin your wheel, treat the wheel and tires as cylinders. For the wheel, the energy needed to rotate it is Iz = (m*r^2)/2. Where m is the mass of the wheel and r is the radius. For the tire, Iz = (m/2)*(R^2+r^2). m is the mass of the tire, R is the overall diameter of the tire, and r is the inner diameter of the tire (or just use the diameter of the wheel). Add the two together and you'll see the total energy. Do it for both setups and take [(IzOld/IzNew) - 1]*100% to find out how much more energy your old setup takes to spin than your new setup. Wiki for equations: https://en.wikipedia.org/wiki/List_of_moments_of_inertiaIf you look at the formula, you're going to notice that a change in radius of the wheel or tire is going to have a larger effect than changing the weight of the wheel. The radius is an exponential. Also, if you think about it, a tire weighs about about the same (+/- 15% depending on wheel and tire setup) of what the wheel weighs. So, technically going to a smaller or lighter tire will likely have more of an effect than a lighter wheel since all of the mass of a tire is outside the perimeter of the wheel (i.e. farther from the center of rotation). Most people have the problem; however, with traction going to a smaller tire. As mentioned before, the rears of a drag car are fat and meaty to get as much traction as possible (notice that a lot of people use lightweight wheels though), but on the fronts, they use pie cutters as they're easier to rotate about its axis.
Re: Lighter wheels
[Re: Mebsuta]
#2066684
05/03/16 08:05 PM
05/03/16 08:05 PM
Mebsuta
Khemi, Stygia
If nothing else, the lighter wheels make it a little easier for me take them off and on and move them around. I didn't care about that 25 years ago but I am starting to now.
