Re: Billet Main Cap Question, Part 2
[Re: Moparguy383]
#2050618
04/09/16 09:06 PM
04/09/16 09:06 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did you ever ask your machinist about this to see how he installed your caps. That would have been my first phone call
[Re: Moparguy383]
#2050621
04/09/16 09:20 PM
04/09/16 09:20 PM
Posts: 2,175 Duloc
The Shadow
Duloc
The cap is 5.14 inches and inside the block is 5.12 inches. there is no way you have .020 interference and the caps were installed
[Re: Moparguy383]
#2050630
04/09/16 09:49 PM
04/09/16 09:49 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
On your first post you stated you had a set of 440 source billet main caps, are they steel or aluminum main caps? Either way before you go to your machinest call 440 Source anbd ask them how much interference fit they want on the main caps you have ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I wouldn't say anything about having problems with the parts yet to 440 Source ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I would tell them that the instructions got lost and you want the straight scoop on the proper fit from them before going to your machine shop ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#2050710
04/09/16 11:52 PM
04/09/16 11:52 PM
Posts: 1,017 Cumberland, MD
Moparguy383
Cumberland, MD
I'm sorry, I should have mentioned they were steel. I will definitely give them a call Monday.
[Re: Moparguy383]
#2050854
04/10/16 05:21 AM
04/10/16 05:21 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My guess is maybe you left a zero out on your readings of the cap and block. 5.012 and 5.014 and not 5.12 and 5.14 which is .020 difference and not .002. If it is .002 interference fit. I know my Source billet caps fit like any have for me after I had my studs installed and had the mains lined bored as I had no problems at all like you are having. Ron
[Re: Moparguy383]
#2051173
04/10/16 05:36 PM
04/10/16 05:36 PM
383man
Balt. Md
383Man,
I am using a digital caliper and the readout says 5.12 inches and 5.14 inches. I don't think I am doing anything wrong.
I meant no offense by it. But wow thats .020 difference then thats not right. Ron
[Re: Moparguy383]
#2051184
04/10/16 05:55 PM
04/10/16 05:55 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
That number CAN'T be possible if the caps have been on block and it line honed. You can look at his pics and see it's not .020
[Re: Monte_Smith]
#2051194
04/10/16 06:10 PM
04/10/16 06:10 PM
dartman366
Mt. Vernon, Ohio
That number CAN'T be possible if the caps have been on block and it line honed. You can look at his pics and see it's not .020 Yes I agree, but I wouldn't use dial calipers for that, too many chances for error and I think that's what you are seeing.
[Re: Moparguy383]
#2051204
04/10/16 06:29 PM
04/10/16 06:29 PM
Moparguy383
Cumberland, MD
383man, No offense taken. Although I have built several engines, this will be the first one that I have put this much effort into. I just want to be sure I am doing it right. It might be wrong, but I was using the tool I have readily available to me.
[Re: The Shadow]
#2051243
04/10/16 07:26 PM
04/10/16 07:26 PM
dartman366
Mt. Vernon, Ohio
I'd love to see how you got a measurement with calipers down inside the block my point exactly.
[Re: 383man]
#2051384
04/10/16 10:28 PM
04/10/16 10:28 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I use my telescoping gauges alot for a measurement like that and then just mike the telescoping gauge. Ron An honestly that not good enough for what he is doing. I use inside Mics and they are always calibrated with my outside Mics that are calibrated with my standards
