Re: Billet Main Cap Question, Part 2
[Re: pittsburghracer]
#2049848
04/08/16 05:04 PM
04/08/16 05:04 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Guys the thing to remember here is this engine had these caps on already when it was line bored. They fit then and they should fit now. Leave the file were it belongs, in the tool box. Chamfer maybe, side of cap absolutely not. If they needed it the machine shop would have done it before the line bore Agreed , taking anything off the cap could change the hole in the cap/block
[Re: JohnRR]
#2049859
04/08/16 05:17 PM
04/08/16 05:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Guys the thing to remember here is this engine had these caps on already when it was line bored. They fit then and they should fit now. Leave the file were it belongs, in the tool box. Chamfer maybe, side of cap absolutely not. If they needed it the machine shop would have done it before the line bore Agreed , taking anything off the cap could change the hole in the cap/block And John your the one that split a block... 2 hits with a file on both sides isnt gonna change DICK and you guys are acting like this is rocket science and its not.. I've seen plenty of machine shops do a ton of stuff that some wouldnt do and they turned them 9000 rpm and .... they lived a long time
[Re: MR_P_BODY]
#2049867
04/08/16 05:32 PM
04/08/16 05:32 PM
Thumperdart
State of confusion
At Pettis it was common practice to hit the main saddles w/a fine file.......
[Re: MR_P_BODY]
#2049872
04/08/16 05:39 PM
04/08/16 05:39 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
My new favorite quote!
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Thumperdart]
#2049874
04/08/16 05:41 PM
04/08/16 05:41 PM
MR_P_BODY
At Pettis it was common practice to hit the main saddles w/a fine file....... I've seen it done many times even after the bore was done.. because they had to much of a problem getting the caps on
[Re: MR_P_BODY]
#2049880
04/08/16 05:49 PM
04/08/16 05:49 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Guys the thing to remember here is this engine had these caps on already when it was line bored. They fit then and they should fit now. Leave the file were it belongs, in the tool box. Chamfer maybe, side of cap absolutely not. If they needed it the machine shop would have done it before the line bore Agreed , taking anything off the cap could change the hole in the cap/block And John your the one that split a block... 2 hits with a file on both sides isnt gonna change DICK and you guys are acting like this is rocket science and its not.. I've seen plenty of machine shops do a ton of stuff that some wouldnt do and they turned them 9000 rpm and .... they lived a long time Do you really think 275 (8 second) runs with a stock 440 block was a BAD thing. I was very very happy to get that many passes out of a stock block at that HP range. Heck that would last most of you guys a life time. LOL
#2049894
04/08/16 06:11 PM
04/08/16 06:11 PM
MR_P_BODY
Guys the thing to remember here is this engine had these caps on already when it was line bored. They fit then and they should fit now. Leave the file were it belongs, in the tool box. Chamfer maybe, side of cap absolutely not. If they needed it the machine shop would have done it before the line bore Agreed , taking anything off the cap could change the hole in the cap/block And John your the one that split a block... 2 hits with a file on both sides isnt gonna change DICK and you guys are acting like this is rocket science and its not.. I've seen plenty of machine shops do a ton of stuff that some wouldnt do and they turned them 9000 rpm and .... they lived a long time Do you really think 275 (8 second) runs with a stock 440 block was a BAD thing. I was very very happy to get that many passes out of a stock block at that HP range. Heck that would last most of you guys a life time. LOL It might last some a life time... I tend to spin them up even stock blocks... LOL and I was in the 8s with my junk
[Re: boatracer572]
#2049929
04/08/16 07:14 PM
04/08/16 07:14 PM
MR_P_BODY
Put the main Capps in your freezer over night, and let the block sit in the sun.... Yep... but most dont do that... IF they are lucky they do the work at room temp.. I had a guy teaching me on machining that came from NASA.. it told me that 5* was the limit for there work.. then it went back into a temp controlled room... so that junk took for ever to machine(with a ton of cutting fluid on the part)
[Re: MR_P_BODY]
#2049941
04/08/16 07:37 PM
04/08/16 07:37 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do you really think 275 (8 second) runs with a stock 440 block was a BAD thing. I was very very happy to get that many passes out of a stock block at that HP range. Heck that would last most of you guys a life time. LOL [/quote] It might last some a life time... I tend to spin them up even stock blocks... LOL and I was in the 8s with my junk [/quote] Not picking here but did you ever run a stock big block? And how long ago?
#2049948
04/08/16 07:42 PM
04/08/16 07:42 PM
MR_P_BODY
Do you really think 275 (8 second) runs with a stock 440 block was a BAD thing. I was very very happy to get that many passes out of a stock block at that HP range. Heck that would last most of you guys a life time. LOL It might last some a life time... I tend to spin them up even stock blocks... LOL and I was in the 8s with my junk [/quote] Not picking here but did you ever run a stock big block? And how long ago? [/quote] Back when I ran a destroke 383.. big rpm engine then a couple of years ago I bought a mega, new Callies crank, and B1m/c heads.. but I ended up selling all that stuff.. again that was gonna be high rpm (9000+)
[Re: deaks]
#2050006
04/08/16 09:17 PM
04/08/16 09:17 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Ya he deburrs the block before the line hone on a chev. And the point is you need to know how to machine a chev??
[Re: MR_P_BODY]
#2050596
04/09/16 08:16 PM
04/09/16 08:16 PM
Posts: 1,016 Cumberland, MD
Moparguy383
Cumberland, MD
II have .02 difference between the cap and the block. The caps are in the freezer and I am going to check again in a while.
I really appreciate all of the good advice and information from everyone!
