Re: Cam and Lifters [Re: Cab_Burge] #2078707
05/23/16 10:39 AM
05/23/16 10:39 AM
SC
DropTrooperZim Offline OP
SC
Originally Posted By Cab_Burge
That tells me it is a 1965 426 Street wedge block thumbs Have you decided what to do on the cam and lifters yet?
Not yet. Im still in the pricing phase. I need a lot of items to get the engine running. Still need to find a flywheel/flex plat/clutch, need to determine what kind of trans I have and if it is compatible with the engine, need to rebuild the small carb I have, need to find 2 pistons(ring landings broke-up), probably need new main bearings cuz Im missing the upper thrust bearing,....the list goes on.
Not even sure where to start with the trans.
If I cant find a rebuild kit for the carb then Ill have to get a new one and they are pricey!
But if I need a new cam and new lifters, should I go ahead and beef them up a little now? Then I would also need new valve springs and Im not sure what lbs and size to look for if I do get an above-stock cam/lifter.
Lot of stuff to process.
Re: Cam and Lifters [Re: DropTrooperZim] #2078851
05/23/16 02:54 PM
05/23/16 02:54 PM
If you use a small cam like the Comp Cams early magnum series or similar with under .500 net lift the stock valve springs should work fine scope
As far as replacing those two stock OEM street wedge pistons look under the bottoms of the pistons and post the casting numbers on here, I may have one good used one in my shop luck
Are you going to use a stick shift tranny or a automatic tranny?
Which carb type and part number are you wanting to use? I use to race a Max wedge car with AFB carbs. and I have a lot of old carb. kits left over so I may be able to make up enough gaskets and parts so you can freshen yours thumbs work scope
Tell us what you want your motor to do as far as street, street and strip or what?
Re: Cam and Lifters [Re: Cab_Burge] #2078959
05/23/16 06:15 PM
05/23/16 06:15 PM
SC
SC
I have this thread looking for a suitable piston replacement:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2043438/re-piston-search.html#Post2043438
Casting number is 2465533; measurements match the pistons in the link=> https://egge.com/part/egg-t100-l2229-8/
Im trying to rebuild the carb I have. Its a Holley with stamp numbers 6253 and 0868
Id like a manual trans but Im not sure what I have. The only number I see on the transmission is 0-95638; the bell housing has the number 3681131.
Im rebuilding on a tight budget so my main objective is to get the engine running. Not going for top performance or strip, just a cruiser. Dropping it into a 66 Coronet that I also have to rebuild.
Re: Cam and Lifters [Re: DropTrooperZim] #2079088
05/23/16 11:02 PM
05/23/16 11:02 PM
If the bell housing is seperate from the tranny it is probally a stick shift tranny twocents Can you post a picture of the parts you have now? If so do that and we'll go from there thumbs
Re: Cam and Lifters [Re: Cab_Burge] #2079933
05/25/16 12:10 PM
05/25/16 12:10 PM
SC
SC
These photos were taken a while back. I have since cleaned all the pistons(the 6 intact), connecting rods, bearings and oil rings(and landings). Ive also dis-assembled the heads(not shown) and cleaned them along with the valves, springs, retainers....Ive reamed the ridges in the cylinders. I still need to chase all the threads, replace the plugs, etc.
Re: Cam and Lifters [Re: DropTrooperZim] #2080020
05/25/16 02:28 PM
05/25/16 02:28 PM
I meant a picture of the tranny and bell housing blush
Re: Cam and Lifters [Re: Cab_Burge] #2080534
05/26/16 10:24 AM
05/26/16 10:24 AM
SC
SC
Trans
Re: Cam and Lifters [Re: Cab_Burge] #2080535
05/26/16 10:25 AM
05/26/16 10:25 AM
SC
SC
Bell housing
Re: Cam and Lifters [Re: DropTrooperZim] #2080567
05/26/16 11:13 AM
05/26/16 11:13 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
That bell housing isn't going to work with that engine or that transmission.
Re: Cam and Lifters [Re: Cab_Burge] #2083296
05/31/16 10:08 AM
05/31/16 10:08 AM
SC
SC
Casting number on the piston is 2465533 - any help would be great!
