Re: The "myth" of ram air.. does it WORK in cars/trucks?
[Re: DARTH V8Я]
#2043470
04/01/16 01:17 PM
04/01/16 01:17 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Ram air busted: because it does not exist, for the following reasons: - Air is incompressible at any automobile speed (I.e. speeds less than Mach 0.3). meaning that the kinetic energy of the air cannot be used to compress the air and raise the static pressure. - The “ram air” nozzles commonly employed on automobiles tend to be the wrong shape. A divergent nozzle is required for ram air. Straight-profile scoops cannot provide a ram air effect. Select one of the two types of intakes, warm air, or cold air. Beyond that its just about looks." Reference https://www.physicsforums.comIntake air temps: The rule of thumb with the average V-8 is 1 hp for every 10 degree (F) drop in intake air temp. That works out to about 1% for 30 degrees. Cold air kits: Busted (sorta) https://youtu.be/gCi2yo4UqPIMost interesting was no air filter made no power gain vs using an standard factory air filter. Makes you think twice about those K&N claims we all seen. Fascinating stuff.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2043524
04/01/16 02:13 PM
04/01/16 02:13 PM
DaytonaTurbo
Manitoba, Canada
Cold air kits: Busted (sorta) https://youtu.be/gCi2yo4UqPIMost interesting was no air filter made no power gain vs using an standard factory air filter. Makes you think twice about those K&N claims we all seen. Fascinating stuff. Yet these guys dyno tested a ~400hp mopar big block and found a 14hp difference between a generic 3" paper air filter in an open element air cleaner versus open carb. Clearly these results would vary with engine air intake demands as well as the efficiency of your existing air cleaner, but the filter they used for their dyno testing was pretty standard in the hot rod community. http://www.hotrod.com/how-to/engine/1307-mopar-engines-power-vs-luxury/
[Re: 360view]
#2043530
04/01/16 02:15 PM
04/01/16 02:15 PM
DaytonaTurbo
Manitoba, Canada
My 1995 Magnum 5.9 V8 seems to have a complicated fender side air inlet system that sucks hot engine compartment air at idle, but when the truck is moving gets cooler air from a passage in the fender that has its inlet up by the passenger side headlight.
It is so complicated that it has to be designed that way on purpose.
My 95 5.2 magnum in a jeep grand cherokee just had a generic factory cold air intake just like you would see on any other modern vehicle. IIRC air was drawn in from the headlight bucket area.
[Re: DaytonaTurbo]
#2043559
04/01/16 02:41 PM
04/01/16 02:41 PM
DARTH V8Я
Its a TRAP!
There's something else at foot there. We did that at the track too. Difference in ET was statistically insignificant with a 400 big block in a 74 Satellite Sebring Plus. I believe the ET's were a consistent 14.2 give or take a hundreth.
[Re: 360view]
#2043563
04/01/16 02:47 PM
04/01/16 02:47 PM
DARTH V8Я
Its a TRAP!
My memory is a bit fuzzy, but on the Spitfire airplanes "reverse ram air" was applied to the engine exhaust manifolds and a worthwhile gain in airspeed resulted.
Meredith effect ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: DARTH V8Я]
#2043591
04/01/16 03:29 PM
04/01/16 03:29 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Air cleaner tests are no good with out carb mixture changes too. This rings true with any induction side testing you do.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: DARTH V8Я]
#2043627
04/01/16 04:21 PM
04/01/16 04:21 PM
Posts: 22,732 Bitopia
jcc
Bitopia
Ram air busted: because it does not exist, for the following reasons: - Air is incompressible at any automobile speed (I.e. speeds less than Mach 0.3). meaning that the kinetic energy of the air cannot be used to compress the air and raise the static pressure. - The “ram air” nozzles commonly employed on automobiles tend to be the wrong shape. A divergent nozzle is required for ram air. Straight-profile scoops cannot provide a ram air effect. Select one of the two types of intakes, warm air, or cold air. Beyond that its just about looks." Reference https://www.physicsforums.com ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) We must have a failure to communicate here. I wonder if those egg heads are getting hung up on the street meaning of "ram", to me in our application, it only means raising the general air pressure in the vicinity that feeds the carb or whatever, anything that does that in our hobby qualifies to me as "ram", if we aren't splitting hairs. We raise the inlet pressure all the time, sometimes lower it un-intentionally, hence all the comments as to the carb needs tuning for fair comparisons. I pretty much lost interest at the "Incompressibility" at less then mach 3 comment.
[Re: DARTH V8Я]
#2043677
04/01/16 05:27 PM
04/01/16 05:27 PM
Posts: 3,104 Michigan
A727Tflite
You get cold air in either case - scoop sealed to the base plate/carb or not - but you pick up power by having a PROPERLY designed scoop sealed to the carb. A poor design can actually SUCK air OUT of the scoop.
On my car in C/SA back in the 70's going 115 or in SS/GA going 125 - hooking up the scoop to the air cleaner baseplate has always produced more power - shown in lower ET and higher MPH.
In fact John Baumman (Chrysler carb expert) jumped in my case when I ran slower at a Milan Test Day after a change in manifolds from the old factory six pack to the STR. When I took the hood off the car and he saw no baseplate he said "there is your problem". I had to "modify" that OE 69-1/2 baseplate with a hacksaw - added some sponge to the outer portion to seal it to the hood - and picked up a solid tenth and 1-1/2 mph. But don't believe any one person - do a base line test - if you have a scoop - attach a sealed base plate to the scoop and make a couple passes then take it off. See what happens. Don't give up because some people offer up invalid assumptions and opinions - TRY IT FOR YOURSELF.
[Re: jcc]
#2043691
04/01/16 05:39 PM
04/01/16 05:39 PM
DARTH V8Я
Its a TRAP!
I pretty much lost interest at the "Incompressibility" at less then mach 3 comment. .(point)3 mach. Around 230mph.
[Re: A727Tflite]
#2043696
04/01/16 05:42 PM
04/01/16 05:42 PM
DARTH V8Я
Its a TRAP!
This is true of people. However the science of fluid dynamics doesn't lie. Great conversation though, interesting opinions ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: DARTH V8Я]
#2043711
04/01/16 05:53 PM
04/01/16 05:53 PM
A727Tflite
They may not lie - but they are subject to interpretation. If all else fails - use scientific instruments. Hook up a manometer to the scoop - like Chrysler did back in the day. Yes - the primary purpose of the street scoops were for fresh (colder) air - the race packages were tested and proven to provide "ram air".
[Re: A727Tflite]
#2043727
04/01/16 06:13 PM
04/01/16 06:13 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
They may not lie - but they are subject to interpretation. (Don't waste yer time... He's already made-up his mind...) 'Ram Air' is a myth... FD trumps all...
[Re: A727Tflite]
#2043744
04/01/16 06:34 PM
04/01/16 06:34 PM
DaytonaTurbo
Manitoba, Canada
When I took the hood off the car and he saw no baseplate he said "there is your problem". I think it stands to reason that without a carb to hood seal, between the speed you put on and the fan turning 5000rpm, the engine bay is enough of a high pressure zone to overpower your tiny scoop.
[Re: DARTH V8Я]
#2044262
04/02/16 10:09 AM
04/02/16 10:09 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A map sensor doesn't show flow turbulence though. turbulent air thru the carb is not optimal. I might need to make one.
