Re: ?Carbs for a cross ram max wedge
[Re: Smoparmike]
#2044508
04/02/16 02:50 PM
04/02/16 02:50 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
64 Max wedges had 750's from factory. All the max wedges I do for big hp street or strip I use the 750"s You will need to jet them right out of the box because they are way to rich. leave the rods stock and use .104 jet in primary and .082 secondaries to start and get you in the ball park.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2044527
04/02/16 03:32 PM
04/02/16 03:32 PM
Posts: 3,916 usa
lewtot184
usa
64 Max wedges had 750's from factory. All the max wedges I do for big hp street or strip I use the 750"s You will need to jet them right out of the box because they are way to rich. leave the rods stock and use .104 jet in primary and .082 secondaries to start and get you in the ball park. this!
[Re: Smoparmike]
#2044541
04/02/16 03:53 PM
04/02/16 03:53 PM
Posts: 44,094 Bend,OR USA
Cab_Burge
If you buy the Edlbrock carbs. make sure and don't buy the smog ones with the electric chokes , buy the Hi Po versions with the manual chokes I've used both versions both on street hemi and M.W. motors, the non smog carbs. are way better out of the box I would use and follow the secondary jetting recommended in the old Mopar drag manuals
[Re: AndyF]
#2044934
04/02/16 11:29 PM
04/02/16 11:29 PM
Posts: 12,536 Taxes & Virus's R-US, NY
Dragula
Dual 500 cfm carbs can easily support 625 hp. I'd use the smaller carbs for something that is going to be street driven. You can go with 750 or 800 cfm carbs if you want. The air valve secondary is pretty forgiving in terms of over carbing an engine. If they actually flowed 500cfm....Those eddy 500's only flow 350cfm or there abouts. I would run 750 or bigger manual eddy carbs with all the choke stuff removed.
[Re: Smoparmike]
#2045330
04/03/16 01:19 PM
04/03/16 01:19 PM
Posts: 14,573 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
With an extra 80 cubes and 200+hp over a stock 426, I don't know that I'd drop the jetting all the way down to what came in a stock MW carb. I'd rather err on the rich side to get it going.
[Re: fast68plymouth]
#2045602
04/03/16 05:35 PM
04/03/16 05:35 PM
Posts: 208 PA
Scully
PA
With an extra 80 cubes and 200+hp over a stock 426, I don't know that I'd drop the jetting all the way down to what came in a stock MW carb. I'd rather err on the rich side to get it going. The cubes and HP should have nothing to do with the jetting, if anything the stock jetting might be too rich.
