Speedo Needle not at 0
#2044500
04/02/16 03:33 PM
04/02/16 03:33 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Guys,
Stupid problem I have been dealing with for the 15 years my Dart has been on the road! When at rest, my speedo needle is down below 0. So, when I am driving, my speed is off. It is a '70 Dart with a Ralleye dash.
I have the cluster out for changing some lights - and before I put it back in, I'd like to fix the speedo issue.
Anyone know how to get the needle to point at zero?
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
Re: Speedo Needle not at 0
[Re: 19swinger70]
#2044613
04/02/16 06:14 PM
04/02/16 06:14 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
When I refreshed the paint on the needle of my dad's 57 Chev, I just pulled it straight off and then installed at like 40, and twisted it back counterclockwise until it was at zero. It was just a slight press fit. I'd suspect that one should be about the same.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: 19swinger70]
#2045023
04/03/16 02:53 AM
04/03/16 02:53 AM
RapidRobert
the magnetic gismo is delicate. I would at least eyeball the innards & see if anything obviously looks damaged. Sounds like yours is way off so either a stop or something will be visually off enough to tell or magnetically it is way off but I'd suspect the first one but I am speculating.
[Re: 19swinger70]
#2045439
04/03/16 03:35 PM
04/03/16 03:35 PM
19swinger70
Richmond, Indiana
Thanks guys. I will handle with caution.
The speedo works - the speed is just low by the same distance that it is off of zero! (around 10 mph)
