Re: Stroker BB 6 pack jetting
[Re: Sixpak]
#2094033
06/18/16 05:31 PM
06/18/16 05:31 PM
Posts: 126 Oregon
Jamie McGrath
I don't think the 4412 has the vacuum hose provisions for diaphragms on secondary end carbs; now mechanical sec. end carbs yea they may be a good choice. Correct, however the boss is there in the main body and would require drilling. Take a second look at 68 Hemi GTS picture, its right there....
[Re: onebadfish]
#2094038
06/18/16 05:38 PM
06/18/16 05:38 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Well, this thread certainly has a variety of theories in it.
The easiest way to (roughly)compare two barrel and four barrel holley style carbs for flow capacity, since they are tested and rated at different pressures, is to compare the Venturi and throttle bore diameters. For example, a secondary OE 6bbl carb has the same size venturi and throttle bore of an 850dp Holley # 4781. A 4412 is the same as a 750dp Holley # 4779. In other words, when tested under the same parameters, 2 4412 Holley carbs don't flow 250cfm more than one 4779. The 2 4412's basically flow the same as a 4779....... Or roughly 375cfm when tested at the 4bbl pressure.
To the OP........ Compared to the stroker 6bbl motors I've tested, that jetting would be pretty lean. For the power levels you're at, we usually end up with secondary jets in the mid-80's. I also agree that with 330cfm heads on a 11:1 shortblock and a 260 @ .050 cam you should have seen a bit more power. 650?? Who knows...... Dynos can vary a lot, but 610 seems like there might be some left on the table.
[Re: onebadfish]
#2094061
06/18/16 06:46 PM
06/18/16 06:46 PM
fast68plymouth
So. Burlington, Vt.
I was using the two 4412's as an example to compare to one 750 4 bbl. The two 4412's equal the one 750 in terms of Venturi area and throttle bore area. Does it seem logical that the two 4412's would flow 250cfm more than the 750?
Does a stock 6 pak center carb flow more or less than a 4412? Look up the Venturi diameter and throttle bore diameter for both, then you tell me.
[Re: fast68plymouth]
#2094272
06/19/16 01:49 AM
06/19/16 01:49 AM
Posts: 126 Oregon
Jamie McGrath
The stock center for a 440 is a 4144 carb, it has a 1.187 venturii and a 1.5 throttle bore for 350cfm. The 4412 has a 1.376 venturii with a 1.688 throttle bore for 500cfm. So I say that the 4412 moves more air. This was from Holley's web sight.
[Re: jbc426]
#2094333
06/19/16 11:02 AM
06/19/16 11:02 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
The wide band was indispensible as far as dialing in the jetting and squirters. I found no need for a chassis dyno and dialed it in on the street using the data logging feature. It makes it pretty easy to do. My hat is off to the guys who dialed them in by the seat of their pants and reading the plugs. Now, that takes some skill!
ayye aye cap .. love my Lm1 and 2 great to have these tools today .
[Re: sogtx]
#2094443
06/19/16 02:19 PM
06/19/16 02:19 PM
Thumperdart
State of confusion
Yep, my junk was runnin low 10`s till I chassis dynoed it w/air fuel capabilities then right into the 9`s............invaluable tuning AID not end all but a directional tool......
