Page 2 of 3 1 2 3
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2040964
03/29/16 02:08 AM
03/29/16 02:08 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Back in the old days the q-jet would run out of fuel (in the bowl) without a very good mechanical pump or an electric pump, where as the Holly had two bowls of fuel so a reg pump could keep for awile longer. I had a 67 SS Chevelle 396 and it never made it through the 1/4 mile before it fell on its face. The main reason no one liked them. Also If you had a Holly you automatically had 200 more hp, if you believed the hype at he time. Q-jet is a very good carb.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041036
03/29/16 09:20 AM
03/29/16 09:20 AM
Georgetown de usa
E
Eggman Offline
Eggman  Offline
E
Georgetown de usa
I'm sending one out to SMI for a stage 2 rebuild to use on my 318 with a whiplash hyd. roller.The last one I ran on a chevy truck ran as good as fuel injection.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041051
03/29/16 09:40 AM
03/29/16 09:40 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The quadrajunk and thermobog suffer from some of the same issues, the most of which are lack of knowledge. The QJ at least has more more support, being primarily a chevy application. The TQ on the other hand suffers from a lack of tuning parts and info. I remember demonsizzler's old thermoquad website had some baseline tuning info on it to get you started. I think that's all gone away now.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041088
03/29/16 10:51 AM
03/29/16 10:51 AM
Tacoma, Washington USA
Adam71Charger Offline OP
This is interesting. I have a 1973 Quadrajet 7043202 FS. I also have a 73 spread bore 440 intake. I have no idea the cfm this carb has, but I'd like to try and rebuild it to get to know them better.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041093
03/29/16 11:00 AM
03/29/16 11:00 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I now own the old Demonsizzler website, www.thermoquads.Com
No reason to reinvent the wheel on TQ tuning when you can learn all you need to know on the Imperial website.
Follow the link below:
Learn How To Adjust Your Thermoquad!
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041111
03/29/16 11:30 AM
03/29/16 11:30 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'm likin' the above "man puzzle", and it appears the #2 gasket is shown bass ackwards, no?
Re: Why do Quadrajet carbs have such a bad reputation? [Re: ScottSmith_Harms] #2041114
03/29/16 11:34 AM
03/29/16 11:34 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Originally Posted By ScottSmith_Harms
Man Puzzle laugh2
When I had the Aussie Charger, I got to know these carbs pretty well. I really liked them actually. up (What the six pack cars used from the factory)
Re: Why do Quadrajet carbs have such a bad reputation? [Re: ScottSmith_Harms] #2041182
03/29/16 01:21 PM
03/29/16 01:21 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Man Puzzle laugh2
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041256
03/29/16 03:35 PM
03/29/16 03:35 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
I just swapped on a Street Demon 625 for my old Qjet yesterday. There is a difference, but not a night and day difference. The Qjet shares concepts with the TQ (I really prefer working with the Qjet over the TQ after having messed with both, though).
I took the time to rebush the primaries and get mine dialed in as best I could, and for a 40 year old carb it worked worlds better than the Carters I tried on the motor before. Started in any weather, good economy, no bogs (tighten the door spring and the pull-off pot so it doesn't start dumping open early, NBD).
Doug Roe's book is a good reference and QuadrajetParts.com was where I preferred to get parts from (nothing against Cliff Ruggles, QJParts just has more selection). If you can come into one for cheap or free that has the adjustable APT, it's worth your time messing with if you're coming from an older Holley or Carter design. If you can just as easily drop $200-300 on a newer-design carb, at the very least you're paying for brand-new and updated systems proven by Qjets and TQs, which isn't necessarily a bad thing.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041313
03/29/16 05:09 PM
03/29/16 05:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Decent running when clean. The small built in fuel filter can get clogged, then it bypasses and lets garbage in the carb, usually sticking the needle/seat and flooding the carb. I put a in-line fuel filter in the fuel line before the carb unless it needs to look stock.
I think someone else mentioned the single needle/seat assembly will limit the amount of fuel that can be supplied to the carb in high HP applications.
The Thermoquad can have issues with warpage and cracking of the main body. Also, on either, you need to check the plugs used to seal the passeges because they can become loose and leak.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041492
03/29/16 09:41 PM
03/29/16 09:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The "Warpage & Cracking" problems with Thermo-Quads is almost mythical yet I have yet to see one come through my shop that was actually warped or cracked from normal use. The broken ones I have seen (and I've only seen a few) were almost ALWAYS caused by someone trying to pry one apart before all the bolts were removed.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041580
03/29/16 11:03 PM
03/29/16 11:03 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Back in the 80's & into the early 90's we bought a lot of GTO's out West, & brought them back to MI. to sell. Also a lot of Mopars & an occasional few Fords. Even a '73 Javelin once. All I can tell you about the Quatrajet carbs, is when a GTO would sit for a week or longer, the carb went dry & the car would not start. You'd have to prime them every time. A Mopar or anything else could sit for a month, & you could get in it & start it right up. That's all I know about Quadrajets.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: ScottSmith_Harms] #2041636
03/30/16 12:04 AM
03/30/16 12:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the TQ I had was from a '76 or 77 Cordoba 360 4-bbl car.
I think it had cracks in the main well area, but I bought the car for $100 not running because the pickup in the tank was plugged up with some black gooey stuff. I think someone mentioned MTBE? or sugar it the tank?
Anyhow, I don't know the history of the carb? I stuck a rebuilt one from an auto parts place on it, and the car ran OK.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Adam71Charger] #2041647
03/30/16 12:26 AM
03/30/16 12:26 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Back when I had General Moronics products 30 years ago, I loved the sound of the QJ's secondaries kickin in.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Why do Quadrajet carbs have such a bad reputation? [Re: mopargem] #2041800
03/30/16 10:26 AM
03/30/16 10:26 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
"quadrajunks" got their bad reputation when a friend of my brothers and his "expert mechanic" [many,many years ago] worked on the carb that was on his 71 or 72 buick. later that afternoon, my brother's pal showed up complaining now his car really didn't run any better after his "expert" tuned it, in fact it ran a ton worse ! well it didn't take any time at all to discover the "expert" put the top on with the metering rods attached. it seems upon tightening everything up, the metering rods were kinda "pretzel" shaped. biggrin a few minutes with pliers, screwdriver adjustments, and a slight timing change [all with use of a vacuum gage], and "geegooollie !" that tank NEVER ran that good ! this still brings up chuckles today when mentioned. to my brother's buddy, not so much ! laugh2
beer
Re: Why do Quadrajet carbs have such a bad reputation? [Re: mopargem] #2042148
03/30/16 05:26 PM
03/30/16 05:26 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Sound as good as a Thermoquad when the secondaries kick in? That's an awesome sound!
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Sunroofcuda] #2042358
03/30/16 10:47 PM
03/30/16 10:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I remember my neighbor under the hood of his kinda new 1968 Impala with a 327 and the Quadrajet and it was around 1971. Him and the neighborhood guys were saying is stumbles and the owner was under the hood with air cleaner off and he was holding the secondary air valve wide open and nailing the throttle. And of course it bogged and backfired a few times. I told him you are not supposed to hold that air valve open as it works by being shut and opening on its own to stop the stumble from all that air at once. Course non of the guys believed me because I was only 15 but I was already into cars big time and knew about the air valve on the Quadrajet and how it worked. I always laugh to myself about that. Ron
Re: Why do Quadrajet carbs have such a bad reputation? [Re: 383man] #2042421
03/31/16 12:03 AM
03/31/16 12:03 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
A carb story I always get a personal chuckle out of is a '72 Cuda 340 I bought off a local guy that "never ran right." This was back in 1985 & the car was a beautiful, all 100% original paint totally rust free car, with a rebuilt 340 with a warmer cam & 202 heads, & the guy that owned it was a Mopar guy from way back. His good buddy was a Chrysler engineer & they both mused over what the problem with the sluggish Cuda was for several years. They theorized that the engine had the wrong cam. Anyway, I caught wind of the car going up for sale & went & bought it.
After a couple of weeks, I decided to look at the carb - a Thermoquad. I could swear the secondaries were not opening - you couldn't hear them. I removed the carb & the first thing that struck me as odd was the secondaries were all carboned-up - just black looking in there. I soon discovered that the secondaries were NOT opening, & tweaked a linkage elbow on the RH side of the carb til they opened every time when the throttle was moved to WOT. I reinstalled the carb & went for a ride. It's like I added 100 HP. A week later I met up with the Chrysler engineer guy while out cruising on a Sat. night. I told him to jump in & took him for a ride. He was estatic: "WHAT DID YOU DO?" I told him about the secondaries.............you could have heard a pin drop.
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Sunroofcuda] #2042459
03/31/16 12:51 AM
03/31/16 12:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can imagine how much better it felt as it was running on just the small primaries ! When them big secondaries kick in it sounds like it wants to suck the hood in. Cool story. up Ron
Re: Why do Quadrajet carbs have such a bad reputation? [Re: Sunroofcuda] #2042468
03/31/16 01:07 AM
03/31/16 01:07 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The qjets ive driven are in no way cooler than the t quads when mashed.
I want my fair share
Page 2 of 3 1 2 3
