Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: can.al] #2049582
04/08/16 11:43 AM
04/08/16 11:43 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Originally Posted By can.al
Originally Posted By ScottSmith_Harms
How about some cam numbers. Remember, pump gas, heavy car, street driven
268 XE would be very lazy in a big car like that until about 40 or 50 mph.
how about the generic 204 / 214, .429 / .444....good lo end torque.
that should break the tires loose and pull good beyond the speed limits
The 268 would be lazy if the stock converter is retained and the rear gear was numerically low.
The cam you posted specs to looks like a actual OE 340 cam. Is this correct?
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049588
04/08/16 11:50 AM
04/08/16 11:50 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Scott, I hate to badger, but we need some more info/help on this build.
What is the rear gear & tire size?
Is a converter change an option? Unless it is a manual trans?
Is the engine going into a full rebuild?
Other than the above recomendation I made about the Comp Cam for exhaust manifolds, I normaly run a split duration cam with unported heads with headers or not, with 8*'s more exhaust. Thus helping with the corked breathing.
Iron headed engines with small cams work very well with a 9.0-1 ratio. (In case this is a full on rebuild.)
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: Rob C] #2049633
04/08/16 12:51 PM
04/08/16 12:51 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...stock 340 lift with much less duration,ideal for a heavy vehicle ..nearly every manufacturer sells a similar grind
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049709
04/08/16 02:33 PM
04/08/16 02:33 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Had a HP 360 in a 74 RR with a 4-speed. Same basic cam as a 340. Was plenty fast. With the 73 Charger I'd put 1.6:1 rockers on the list. Shave the heads to get as much compression as possible. Pocket port, gasket match. Put a strip kit in that TQ. IF budget allows put more converter & lower gears.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 340 Stock Stroke Street Build Recipie For a 73 B-body [Re: ScottSmith_Harms] #2049838
04/08/16 04:55 PM
04/08/16 04:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Scott,contact AJ at BGR,he has a 340 engine complete that has 6 pak heads and flat tappet cam,polished single four Mopar intake,polished aluminium valve covers,Roller rockers,deep pan,Fluid Damper and extras.It was in a 3400 lb Cuda,rotating assembly is balanced.We built this engine back in mid 90s and it just has been setting around.It ran consistant low 11s and in good air ran 10.90s.
AJ at BGR 412-216-4727
