Page 5 of 7 1 2 3 4 5 6 7
Re: 318 for drag race use [Re: 408Dust] #2040395
03/28/16 01:38 PM
03/28/16 01:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Originally Posted By 408Dust
Originally Posted By Quicktree
[quote=qwkmopardan]I missed it by a little. If he assembles it himself about $6300
Grind crank $200
Pistons and rings $750
Scat rods $350
Main and rod bearings $125
Balance assembly $300
Bore and hone w tq-plate $275
Square deck block $175
Align hone block $300
Hot tank and crack check block $125
Cam bearings and freeze plugs, installed $125
Restrictor tubes and oiling mods. $200
Timing chain set $100
Cam and lifters $325
Porting, valve job and springs $1000
Victor 340 intake $300
Hughes rocker arm kit $500
Port intake $225
Smith Bros pushrods $175
Cometic head gaskets $175
M72 oil pump $45
Moroso oil pan and pick-up tube $300
Other gaskets $100 oil pan, intake, rear seal, timing cover, etc.
ARP main cap bolts $50
ARP head bolts $85
Did I miss anything?
good luck with that, the RPM'S will kill those hughes rockers in a minute. the cam and springs it will take to get there will probably be a lot more than you quoted. sorry i just don't see it. be interesting to see this happen. you could save the class racers a lot of money if you could make it happen.
That's for sure guess Parson&Meyers, Tillburg and others have been over charging people for class motors LOL
lol man you could have saved a ton of money laugh2
Re: 318 for drag race use [Re: 318 racer] #2040415
03/28/16 02:05 PM
03/28/16 02:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
There were no 750 thermoquads. The factory generally used 800s on SBs and 850s on BB. There were some aftermarket ones up to 1000 CFM
Re: 318 for drag race use [Re: HotRodDave] #2040487
03/28/16 03:53 PM
03/28/16 03:53 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks for correcting on that. bow
Fastest 300
Re: 318 for drag race use [Re: 318 racer] #2040535
03/28/16 05:01 PM
03/28/16 05:01 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
Originally Posted By 318 racer
I thought about that,but if I would go that route...then it's time for a 360...and I have several 318's here in my shop.
I know this is feasable..I've seen NHRA GT cars use a 318...so it can be done,but I dont think I need a super stock engine build to do what I would like to do.
Keep in mind that a ss gt 318 is a short stroke big bore to make 318 ci.
Re: 318 for drag race use [Re: 318 racer] #2040553
03/28/16 05:34 PM
03/28/16 05:34 PM
Georgia
3
318 racer Offline OP
Georgia
Never thought of that Vance. Excellent point!
On the Edelbrock heads...I forgot that the person I got the heads from also included a set of valves ( I think Ferrea) anyway,they are the small 318 valves. He was going to build a GT combo,but gave up on it,said he'd have too much in the heads.The seats are for 2.02 valves. No problem as I have a set of stainless 2.02 valves and exhaust valves too.
Re: 318 for drag race use [Re: 318 racer] #2040569
03/28/16 06:01 PM
03/28/16 06:01 PM
an8sec70cuda Offline
Those SS/GT motors are pretty high maintenance too. A friend runs one...pistons w/ only one compression ring. Requires freshen ups every 50-60 passes. His "factory unported" cast iron heads cost over $7,000 a set.
7" torque converters, not to mention a trick Quadrajet.
Comparing a typical low maintenance bracket motor to what these SS/GT motors run, well, it's just not a good comparison.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 318 for drag race use [Re: 318 racer] #2040625
03/28/16 08:02 PM
03/28/16 08:02 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have a 318 in my car. Times in my signature.
I think with more gear( run street friendly 4.10) a single plane intake ( knockoff dual plane currently), roller cam( currently a 231@50 hydraulic in it) more compression(10.5) good set of headers(99 dollar cheapies on it)
And removing the power steering, factory water pump and fan, what I have with those mods would go at least 11.20's without much of a sweat.
The heads are ported magnum RT units. Edelbrock magnums ported would I am sure make more power and save some weight.
I can see getting in the 10's pretty easily with the right parts. I am shifting at 6200 and trapping at 5900, not optimal.
This all said, this motor was built and screwed together with excellent machining and thought, that is definitely worth something.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 318 for drag race use [Re: 318 racer] #2040653
03/28/16 08:43 PM
03/28/16 08:43 PM
Georgia
3
Georgia
Another example of a good build. I still think 10.90's are easily done,probably a stretch if I wanted to go 10.50-10.70..but if you dont aim high,you'll never get anywhere.
Re: 318 for drag race use [Re: v cummins] #2040796
03/28/16 11:04 PM
03/28/16 11:04 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
No, stroke is only allowed to be +/- .015" from stock, and bore is allowed to be no more than .080" over stock.
Re: 318 for drag race use [Re: LSP] #2040814
03/28/16 11:19 PM
03/28/16 11:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So a 318 is really a 340
wave
Re: 318 for drag race use [Re: 318 racer] #2040816
03/28/16 11:24 PM
03/28/16 11:24 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Bw,s combo is running nice. While he did manage a 11.79, its other et,s were more closer to a 12 sec. combo IMO. Dumping the WP/fan/ps pump wont gain the .6 in ET imo, more like .25 maybe.
Going from a 12 sec, combo to a 10.50 wont be nearly as easy. Don't let BW,s 231@ .050 fool you, its pushing .600 lift. Hes got a decent vert to back it up too.
I will say, it wouldn't be a bad thing to Follow BW,s build and combo to do what you want to do though. up
Re: 318 for drag race use [Re: MR_P_BODY] #2040822
03/28/16 11:30 PM
03/28/16 11:30 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
wave
329, the good rings stop at 3.970", the 340's end up around 352. As the years go by the max overbore allowed has increased to extend block life.
Re: 318 for drag race use [Re: LSP] #2040868
03/29/16 12:39 AM
03/29/16 12:39 AM
FastOne Offline
FastOne  Offline
In 1995 Mopar Tech published an article on a 273 ci Dart called "Darn Dart", it ran a best at the time of 10.86, running OEM block & crank, 11.5.1 compression, iron 340 X heads, single 4 bbl carby, .508 hydraulic cam, 5.50 gears dodge 8-3/4, weight 3,000 lbs, 345 HP
Re: 318 for drag race use [Re: FastOne] #2040883
03/29/16 12:56 AM
03/29/16 12:56 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Some things wrong with some of the above numbers. Most HP calculators will put 3000# and 345 HP around a 12.5 + ET
Re: 318 for drag race use [Re: Sport440] #2040915
03/29/16 01:47 AM
03/29/16 01:47 AM
fla
ss/la Offline
ss/la  Offline
fla
Can you make a 318 run 10.60? Yes is it cheap? No you have to have the right parts in the right place it can be done and has been done there are at least 5 or 6 super stock cars right now that can prove it but most of the replies about parts are way off wrong intake wrong size headers a 2 ring piston is 20 year old technology if you really want to know talk to somebody doing it super stock cars have nothing in common with bracket cars
Re: 318 for drag race use [Re: ss/la] #2040933
03/29/16 02:00 AM
03/29/16 02:00 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Bingo. And there you have it
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 318 for drag race use [Re: Sport440] #2040934
03/29/16 02:01 AM
03/29/16 02:01 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Right.
But going to a roller, more compression and gear, along with a head upgrade would make a big difference. Car has a flat hood too. That doesn't help.
The cam in it now isn't the engine masters 247/247 solid. It's a hydraulic, and much smaller duration wise.
1.41 best 60 foot
6.56 at 104.17
Re: 318 for drag race use [Re: ss/la] #2040958
03/29/16 02:50 AM
03/29/16 02:50 AM
408Dust Offline
408Dust  Offline
About time you chimed in I was feeling all alone trying to explain it.If it was easy and cheap everyone could/would do it.
Re: 318 for drag race use [Re: Sport440] #2040971
03/29/16 03:32 AM
03/29/16 03:32 AM
FastOne Offline
FastOne  Offline
Dunno Sport440, maybe he had a good tail wind that day, like a Hurricane, lol
Re: 318 for drag race use [Re: 318 racer] #2041044
03/29/16 10:27 AM
03/29/16 10:27 AM
fla
ss/la Offline
ss/la  Offline
fla
the main thing people don't realize in super stock you cannot raise compression or change stroke mas a matter of fact when you put valve reliefs in the piston your compression is actually less for a 318 compression is in the 8.7 range stroke is + or - .015 you don't have a lot to work with every thing is set at factory specs so unlike most racing you cannot just bolt on a new set of heads or raise compression I will not give specifics on an open forum very proprietory information
