Re: Preferences on cage design?
[Re: sgcuda]
#2045565
04/03/16 05:34 PM
04/03/16 05:34 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have never tried using a sharpened tungsten. I Tig welded aluminum for 20 years at work and liked my tungsten about even with the end of the cup. Every weld I made was looked at by 3 different inspectors. If one of them did not like it I got it back.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2045575
04/03/16 05:49 PM
04/03/16 05:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have never tried using a sharpened tungsten. I Tig welded aluminum for 20 years at work and liked my tungsten about even with the end of the cup. Every weld I made was looked at by 3 different inspectors. If one of them did not like it I got it back. For alum I put the machine on reverse DC and with a brass cup under the tip held vertical give the pedal a hit and that gives you a perfect round ball so the power runs around in a circle which heats both parts.. works very good (of course you have to go back to AC).. I learned that from my aircraft stuff.. and I showed it to one of the welding instructors and thats what he teaches now
[Re: sgcuda]
#2052206
04/11/16 10:03 PM
04/11/16 10:03 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Racerx; let me know what you think. I'm going to make a run for a refill on my Argon before I start the cage. If I need different tungstens, I'll get them too.
[image][/image]
[Re: sgcuda]
#2057166
04/18/16 09:39 PM
04/18/16 09:39 PM
sgcuda
Seems like I have my bad days and my good days. Welded up the right rocker rail and brackets Saturday. Kept melting down the tip all day. I thought it was the hardware I bought from Lowes causing issues. Sunday I welded up the whole left side assembly, and never once had to sharpen the tip. Go figure. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Converted my welder back for Mig to weld the mild steel brackets to the rocker sills. Practiced for a while, trying to get a baseline again. Used an old piece of roll bar tubing. Couldn't get the right heat (too cold, no penetration), splattering all over the place. Changed nozzles, and found the new tip I put on was bent, causing binding in the feed wire. Better, but still having issues. Seems like I can't get a decent puddle or feed the wire properly. Tried on some 3/32" plate, just some practice beads. Didn't even like the way they looked. Welder is designed to handle 3/8" plate. Triple checked my ground. Does spool wire have a shelf life? This spool has been on my machine for a while.
[image][/image]
[Re: sgcuda]
#2057210
04/18/16 10:37 PM
04/18/16 10:37 PM
Posts: 11,855 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've used some cheapy Chinese wire that was horrible. Wouldn't run regardless what you did. Some welding stores even sell this trash.
[Re: sgcuda]
#2057227
04/18/16 10:54 PM
04/18/16 10:54 PM
Posts: 22,837 Bitopia
jcc
Bitopia
Is your Mig polarity correct?
[Re: sgcuda]
#2057362
04/19/16 01:15 AM
04/19/16 01:15 AM
sgcuda
Yes. Welder is even marked "Ages 3 and up". Seriosly, the Mig side only hooks up one way. (Pretty sure, anyway) But I will double check tomorrow. Thanks for the advice. I'm also thinking that I have never changed the liner, migh be due for replacement.
[image][/image]
[Re: sgcuda]
#2058103
04/20/16 01:19 AM
04/20/16 01:19 AM
sgcuda
OMG!!! What an idiot!!! I can't believe I did that. Polarity was reversed for Tig setup. I never put it back for Mig. I didn't even know that would work. Gas ports drilled on both + and - terminals. Thanks JCC.
[image][/image]
[Re: jcc]
#2058119
04/20/16 01:37 AM
04/20/16 01:37 AM
MR_P_BODY
I only speak from making the same oversight. Same here.. when I want to set up my tig electrode for alum I ball it using DC reverse (I do a few tips usually after I'm done with the job just to be set up for the next job) and I have forgot to flip over.. mine is just flipping a lever ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: sgcuda]
#2058124
04/20/16 01:46 AM
04/20/16 01:46 AM
MR_P_BODY
I guess that explains why the tip was glowing but I couldn't heat up the steel. ![weld weld](/ubbthreads/images/graemlins/custom/weld.gif) On to bigger and better. Now you know how it acts... and you will remember.. thats how you figure out stuff.. by messing up ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
