Re: how to clean a bare block
[Re: can.al]
#2042048
03/30/16 04:24 PM
03/30/16 04:24 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
http://www.canadiantire.ca/en/automotive...content=Defaultthis stuff it's a gel and cheap might need a couple three bottles. just called rust remover by dominion sure seal products. I really got a lot of rust of an block with it that had been cleaned and machined but sat 4/5 years in a real damp garage. when I was done light hone with a spread hone and i used it. :-) took a few coats in some areas.
[Re: can.al]
#2042984
03/31/16 09:26 PM
03/31/16 09:26 PM
Posts: 2,175 Duloc
The Shadow
Duloc
You can also try an oxalic acid bath. Rust will turn yellow and wipe off.
