Re: engine paint [Re: 383man] #2039461
03/26/16 11:37 PM
03/26/16 11:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted By 383man
Originally Posted By dvw
Regardless of color or gloss single stage urethane will give the best durability. Unaffected by brake clean, carb clean, etc. You can get any color or gloss. Clean with DX 440, epoxy prime and spray. I have stuff that looks like this that is 20 years old.
Doug
Doug where do you get that paint you used on your 64's eng as I really like that ? Ron
Ron it's just regular single stage urethane. I just mixed it up to be somewhere close to Max Wedge orange.
Doug
Re: engine paint [Re: lewtot184] #2039582
03/27/16 09:46 AM
03/27/16 09:46 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
How does the urethane hold up to gas? Should be fine right? If you spill gas on your quarter the pint doesn't loft right away. The Eastwood quart can I used, it came out nice but lifted on the intake when I had a carb Leak. That got me mad as they say it is resistant to all kinds of chemicals. Wouldnt gas or oil be the most common chemical an engine might see?
I used to have a 30s car and I painted the engine, I happened to have a can of green rust oleum that looked close enough to the original color. I thkinned it and sprayed it. That held up way better than I ever would have thought.
Re: engine paint [Re: JAMESDART] #2039624
03/27/16 10:49 AM
03/27/16 10:49 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive spilled plenty of gas on mine with no prob.its all about the cleanliness of the surface and i dont use primmer.
Re: engine paint [Re: dvw] #2039646
03/27/16 11:20 AM
03/27/16 11:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Doug
Doug
Oh ok. Thanks , Ron
Re: engine paint [Re: lewtot184] #2039651
03/27/16 11:32 AM
03/27/16 11:32 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I did use epoxy primer and I a!always wondered if that had something to do with it lifting.
Re: engine paint [Re: JAMESDART] #2039678
03/27/16 12:16 PM
03/27/16 12:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I always use DP90 epoxy. The trick is cleaning. Do not use lacquer thinner or brakeleen as a final prep. Use DX440 grease and wax remover. Soak a rag, wipe, then wipe with a dry rag.
Doug
Re: engine paint [Re: lewtot184] #2039742
03/27/16 01:54 PM
03/27/16 01:54 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I used the dplf epoxy, i painted it within the alloted time frame. I think the paint lifted from the primer with the carb leak.sometimes I wonder how people keep their engines so good looking when the car is actually driven. The next ones i am empted to spray with black urethane .
Re: engine paint [Re: lewtot184] #2039887
03/27/16 05:11 PM
03/27/16 05:11 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I used Plasticote Hemi orange over the Plasticote engine primer. That's what Barton was using on my engine. I had to paint my water pump etc after the dyno session before installation. So far it's held up well after about 4 years.
Re: engine paint [Re: HEMIDOG 70] #2043548
04/01/16 01:29 PM
04/01/16 01:29 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Plastic coat works the best for spray bomb. It is available through Amazon.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: engine paint [Re: lewtot184] #2043826
04/01/16 06:59 PM
04/01/16 06:59 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've used Plasti -Kote for years,holds up well. What I do is use the Hemi orange,then use the clear over that. Never any peeling or problems. I like the new Rust Oleum Chrysler orange,but it's a shade darker than the Plasti Kote.
Nautilus Racing-
Re: engine paint [Re: lewtot184] #2043930
04/01/16 09:17 PM
04/01/16 09:17 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I use PPGs DP primer then DCC new Kubota orange, wow does it look good!
(Kubota tractors) It gets a lot of complements from the mopar crowed, if they only new.
Have a great day
Iowan
"obsolete is neat"
Re: engine paint [Re: lewtot184] #2044535
04/02/16 03:50 PM
04/02/16 03:50 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
I was turned on to Seymour MRO industrial paint. It's available in Chrysler colors. I like the Omaha orange (race Hemi) stuff holds up really well.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
