Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: dart67] #203929
01/26/09 04:51 PM
01/26/09 04:51 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
dart67,
The attached photo shows my plan. I put the Oil Pressure between the Tach & Speedo. This also allows me to put the Oil Lamp directly above the gauge and between the turn signal indicators. Food for thought.
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: DartGTDan] #203930
01/26/09 07:59 PM
01/26/09 07:59 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Thanks Dan! I appreciate the help! I bought angle rings for the smaller gauges....that's what is keeping me from putting the bigger gauge farther out. But I might have to re-think that approach.
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: DartGTDan] #203931
01/26/09 08:01 PM
01/26/09 08:01 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Dan, where does your headlight switch go?
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: DartGTDan] #203932
01/27/09 01:35 PM
01/27/09 01:35 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
dart67,
I wouldn't put the fuel between the tach and speedo like you have it in the second one. When things get interesting your only going to want critical information and having the oil pressure between the tach and speedo makes more sense to me.
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: DartGTDan] #203933
01/27/09 05:08 PM
01/27/09 05:08 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I like two...for the sole purpose that the others dont have enough meat between the 5" gauges, it will be weak right there....
Where will your radio go? I had my two 5" Autometers with a Vac Gauge btween them dead cent with driver...off to the right I had the two water, Volts....over the other two...Fuel, Oil Pressure...Then the radio in the regular position and the heater controls right above...
I'll upload a pic if you life....Mine more or less looked like a 69 A-Body 340 Rallye Dash
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: Pyper70] #203934
01/27/09 06:39 PM
01/27/09 06:39 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I've been thinking about putting the radio in the glovebox........
Sure would like to see the pic of your dash.
Would you use bondo to smooth over the welds on the sides?
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: dart67] #203935
01/27/09 08:05 PM
01/27/09 08:05 PM
DartGTDan Offline
DartGTDan  Offline
dart67,
I plan on putting my headlamp & wiper motor switches, in the dash frame, to the right of the gauge cluster, left of the HVAC/Radio. I know I'll have to "stretch" the headlamp switch wires, but the wiper motor switch should have plenty of length.
Dan
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: dart67] #203936
01/31/09 08:10 AM
01/31/09 08:10 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I'd use fiberglass, that's how I covered the mountings on my dash. I never got to finish my dash but I had made the flat panel for the glove box as well and was ready to start updating the car with modern equipment like a handbrake, LEDs, etc.. more pics are on my website linked below
if you are interested in the angular bezels thy come in a variety of colors and sizes. I got mine from Rex Marine in Riverside, Ca. I even picked up all the angular bezels in anodized blue for my 76-85 Jeep....and I haven't even bought the Jeep yet....One day
Re: Dash insert : Gauge layout,3 pics, which do you like? [Re: Pyper70] #203937
02/01/09 11:30 AM
02/01/09 11:30 AM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Thanks for the pic! Been off the net for a few days. Ice storm and no power. Got a generator going.
I like your set-up......when things get back to normal around here, I'm gonna give mine another look.
Re: Dash insert : Gauge layout CHANGES [Re: dart67] #203938
02/17/09 09:40 PM
02/17/09 09:40 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
What do you think? I know it's not one of the original 3.
Re: Dash insert : Gauge layout CHANGES [Re: dart67] #203939
02/17/09 09:42 PM
02/17/09 09:42 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
In the car.
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: dart67] #203940
02/17/09 09:45 PM
02/17/09 09:45 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I decided to try this because I can see the gauges easily. I don't think it looks the best of the 4, but it's functional. I'm not done, and might still make changes. The heater controls will go under the 3 gauges on the right.
Kevin
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: dart67] #203941
02/18/09 05:00 PM
02/18/09 05:00 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
Nice work!
vm
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: vynn3] #203942
02/18/09 10:12 PM
02/18/09 10:12 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Looks great. IMO I would grind the welds and coat it with mud, I really don't see a need to glass it. Shape the bondo, glaze coat, prime, block, prime, paint. Also, I would have welded the back side. But it will look great when its installed, nice work.
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: redruM] #203943
02/18/09 11:25 PM
02/18/09 11:25 PM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Looks REALLY good.
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: Kilroy was here] #203944
02/19/09 12:27 AM
02/19/09 12:27 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Looks good to me. And besides, doesn't matter how it looks if you can't see the gauges.
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: DaytonaTurbo] #203945
02/19/09 06:08 PM
02/19/09 06:08 PM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
I hope it turns out good. Think I will go with the mud.
What type paint would you use? Thinking about a black dash pad, gunmetal ( Same as outside of car ) dash frame. Black insert? Or maybe the krinkle? type paint? Ideas????
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: dart67] #203946
02/21/09 08:16 AM
02/21/09 08:16 AM
Ky.
dart67 Offline OP
dart67  Offline OP
Ky.
Any ideas on paint?
Re: Dash insert : Gauge layout CHANGES UPDATE [Re: dart67] #203947
02/21/09 09:46 AM
02/21/09 09:46 AM
Virginia
BSharp Offline
Righteous, and as a result, fearless of mods
BSharp  Offline
Virginia
That layout looks good. A plumbing supply place may have plastic pipe or a fitting you can use to make angle rings. That's what I did.
