Re: What is the best way to kill 4-5 tenths for index racing? [Re: nss guy] #2038060
03/24/16 09:33 PM
03/24/16 09:33 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Would you still be able to cut a decent light on a pro tree (4 tenths tree)footbraking if you something like the throttle stop above.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038086
03/24/16 10:03 PM
03/24/16 10:03 PM
Dover,, Pa
hemiaddict Offline
hemiaddict  Offline
Dover,, Pa
Keep it simple. Try unhooking the linkage to the rear of the carb. Run it as a two barrel. It will put you close. Then adjust weight, take it out or put some in as needed. It wooked very good on a 3000 pound car that ran 10.40s. first run went 10.88. A trick Steve Petty showed me 10 years ago. Jr
Jr Baum
SS/AH 1979
Re: What is the best way to kill 4-5 tenths for index racing? [Re: B1HEAD_USER] #2038117
03/24/16 10:49 PM
03/24/16 10:49 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Originally Posted By B1HEAD_USER
This is what I would use EZ PLATE
This is the best way, the champ in10.0 has had it in there cars past few years at our track.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: What is the best way to kill 4-5 tenths for index racing? [Re: MR_P_BODY] #2038172
03/25/16 12:09 AM
03/25/16 12:09 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Originally Posted By MR_P_BODY
If you can you can, slide the throttle cable housing
forward to give you less throttle... it takes a lt
more than you think
wave
I'm cheap and was considering this. Maybe mark the cable in increments once I can tell how much a set amount kills.
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038181
03/25/16 12:29 AM
03/25/16 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
more than you think
wave
I'm cheap also... I made my mech throttle stop.. very simple
and it works.. I'll see if the pic will post... I made this
for my 1050 dom.. but you can see the idea
EDIT
The front round part slides into a hole the then
rolls down over the rear carb stud... I did this
so I could change over quickly so I could race
2 classes.. took all of about 2 minutes to change
that and reset the shift light and 2 step
I ran 6 or 7 10.002-10.007 in a row doing it this
way.. I was super happy with it
wave
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038188
03/25/16 12:47 AM
03/25/16 12:47 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Put a 'Glide in it . . . . . . Too obvious?
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: What is the best way to kill 4-5 tenths for index racing? [Re: Evil Spirit] #2038195
03/25/16 01:00 AM
03/25/16 01:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah that would be the cheap way to go
wave
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038227
03/25/16 01:48 AM
03/25/16 01:48 AM
America
WedgeFED Offline
WedgeFED  Offline
America
I know many people that use the ez plate. Deadly consistent also...
http://www.restrictorplate.com/howitworks.html
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038241
03/25/16 02:18 AM
03/25/16 02:18 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would spend about $1000 on things that you thing should make it go faster lol
68 Barracuda Formula S 340
Re: What is the best way to kill 4-5 tenths for index racing? [Re: Bad340fish] #2038247
03/25/16 02:28 AM
03/25/16 02:28 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Hmmm, interesting... wrench runaway
Re: What is the best way to kill 4-5 tenths for index racing? [Re: MR_P_BODY] #2038289
03/25/16 05:41 AM
03/25/16 05:41 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
wave
Well, Mike, GY3 didn't mention CHEAP in his original post, so I just tossed an option on the table that nobody else had mentioned. Many, if not most cars that are set up to run 1/4 mile slow down both 60' and ET when a 'Glide is installed. In their defense, they are usually more consistent, less dependent on track prep, a little easier on drive line, and need less of a burnout, which saves on tires.
So while not a cheap option, it's a valid one wave work whistling
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038327
03/25/16 10:25 AM
03/25/16 10:25 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I would use a combination of weight and plate.
Getting old just means you were smarter than some and luckier than others.
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038364
03/25/16 11:22 AM
03/25/16 11:22 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I think the Grid is the easiest. And it lets you leave WFO to try to cut the .400 light
2011 Drag Pak Challenger
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038386
03/25/16 11:47 AM
03/25/16 11:47 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've been running index since the early 90's. A fine thread bolt is as good as anything. I've found the car leaves the same on or off the stop. Have slowed my car .70 this way. With proper record keeping you can learn how to move the car .01. Won a lot of N/SS races with this method.
Doug
Re: What is the best way to kill 4-5 tenths for index racing? [Re: GY3] #2038566
03/25/16 04:06 PM
03/25/16 04:06 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
When I first bought the Arrow it would run 9.60s all out. Believe it or not with only 4 tenths in the timer and an air operated T/S the car was killer consistant.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: What is the best way to kill 4-5 tenths for index racing? [Re: Bad340fish] #2038646
03/25/16 07:06 PM
03/25/16 07:06 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
thumbs
