Re: J/Y Electric fan upgrade
[Re: 451Mopar]
#2040589
03/28/16 06:49 PM
03/28/16 06:49 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My cooling issues were just with the A/C on and even at highway speeds, that is why I am thinking the airflow through the core may be the issue. If the fans were running while you are on the highway they can actually block the air flow. I ran that experiment several years ago. While cruising the highways around Dallas on a hot summer day I would cycle the fans on and off. The temp went up with the fans on at 65 mph.
[Re: roe]
#2041605
03/30/16 12:30 AM
03/30/16 12:30 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I have a fan setup off of a Dodge intrepid, similar to the contour setup and it works well.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2041808
03/30/16 11:34 AM
03/30/16 11:34 AM
Posts: 3,344 Central TX
roe
Central TX
Any pics? I know keeping the parts all Mopar appeals to some folks and might like to use that instead of the Contour fan.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#2043160
03/31/16 11:41 PM
03/31/16 11:41 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Any pics? I know keeping the parts all Mopar appeals to some folks and might like to use that instead of the Contour fan. The Contour Fans are made by Bosch (at least originally) anyway and there aren't any visible Ford logos. The "All Mopar" thing is a joke when the same suppliers basically designed made all the parts anyway. The ford fans are the best first because the V6 Contour is a ridiculous application for fans (just look under the hood), they are common, they make new parts to service everything, and the dual speed feature is amazing. You pretty much won't find the dual speed feature on anybody else's cars.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#2049422
04/08/16 01:38 AM
04/08/16 01:38 AM
roe
Central TX
Any pics? I know keeping the parts all Mopar appeals to some folks and might like to use that instead of the Contour fan. The Contour Fans are made by Bosch (at least originally) anyway and there aren't any visible Ford logos. The "All Mopar" thing is a joke when the same suppliers basically designed made all the parts anyway. The ford fans are the best first because the V6 Contour is a ridiculous application for fans (just look under the hood), they are common, they make new parts to service everything, and the dual speed feature is amazing. You pretty much won't find the dual speed feature on anybody else's cars. I hear ya. For me if its an upgrade that makes sense and lets me drive more, I really don't care what it came on originally. But some guys do so they may like the idea of the one from the Intrepid better. Shatar4: my shroud makes contact against the rad fins. The fans don't rub or hit at all. the plastic should be fine. Seems to be made of the automotive plastics that hold up just fine to hot temps. No issues for me while it was running. The aftermarket fans that were replaced by the contour fans were mounted the same and no issues with the heat either.
[Re: Bad340fish]
#2049453
04/08/16 03:56 AM
04/08/16 03:56 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a fan setup off of a Dodge intrepid, similar to the contour setup and it works well. There is a guy in my area that has an Intrepid fan system for sale and I will try to pick it up on Sunday.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
