Re: Trick Flow heads
[Re: M_D]
#2040375
03/28/16 11:56 AM
03/28/16 11:56 AM
Posts: 31,248 Oregon
AndyF
Andy, that's a nice looking piece, it should be useful too. Instead of wondering how well the valve train is being oiled it can be verified without running it until parts are either smoked or survive the test of time. Thanks for posting a finished picture. Yeah that was the idea. And since the local engine guy builds a lot of Mopar big block engines I'll loan him this valve cover so he can use it for dyno testing and engine break in. A lot of times customers bring in random valvetrain parts and we might be able to solve problems up front rather than down the road by double checking the oiling before the engine goes out the door.
[Re: fast68plymouth]
#2040492
03/28/16 03:00 PM
03/28/16 03:00 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Andy - another cool AR product with the clear valve cover. The ported M1 intake looks awesome! Looking forward to the results vs the untouched M1.
2 kids and a dog
[Re: Skeptic]
#2040682
03/28/16 08:20 PM
03/28/16 08:20 PM
AndyF
Any chance of trying out the TF hyd roller cam? It's smaller than you have been using, but I curious as to how much power it really can make. I don't think I'm up for testing that cam. It is 20 degrees smaller than what I'm currently running so I think it would kill off a ton of power. Probably be a smooth running tire frying monster in a street car though.
[Re: AndyF]
#2040706
03/28/16 08:38 PM
03/28/16 08:38 PM
Posts: 4,396 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Any chance of trying out the TF hyd roller cam? It's smaller than you have been using, but I curious as to how much power it really can make. I don't think I'm up for testing that cam. It is 20 degrees smaller than what I'm currently running so I think it would kill off a ton of power. Probably be a smooth running tire frying monster in a street car though. No problem, They claim 620 HP with the TF heads and that cam on a 10.5:1 440.
[Re: Skeptic]
#2040807
03/28/16 10:14 PM
03/28/16 10:14 PM
AndyF
Any chance of trying out the TF hyd roller cam? It's smaller than you have been using, but I curious as to how much power it really can make. I don't think I'm up for testing that cam. It is 20 degrees smaller than what I'm currently running so I think it would kill off a ton of power. Probably be a smooth running tire frying monster in a street car though. No problem, They claim 620 HP with the TF heads and that cam on a 10.5:1 440. I believe their 620 HP claim. I bet that cam in my 470 would also make about 620 hp. I'm making 685 hp with a solid roller that is 20 degrees larger as well as a Dominator carb. If I used their cam, intake and carb I'd probably be fairly close to 620 hp also.
#2050105
04/08/16 11:37 PM
04/08/16 11:37 PM
Posts: 14,544 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Impressive numbers. Was there a gain in leak TQ as well?
Is the TF intake going on next?
Did you get another 4500 carb to try? (I can't recall if that was part of the plan)
#2050109
04/08/16 11:42 PM
04/08/16 11:42 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I like the headers what size are those? They should up the numbers some.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
#2050376
04/09/16 12:35 PM
04/09/16 12:35 PM
AndyF
Did you get another 4500 carb to try? (I can't recall if that was part of the plan) I tried two Dominator carbs. A 950 and a 1050. The 1050 carb made 10 hp more than the 950 carb. I did also try the new Trick Flow low deck intake. This is a very nice intake, I think it is a better design than the Victor since it doesn't have the big eyebrows in the plenum that the Victor has. I used a new 1050 AN carb from Quick Fuel. This combo made 690 hp @ 6500 rpm.
#2050472
04/09/16 03:33 PM
04/09/16 03:33 PM
fast68plymouth
So. Burlington, Vt.
Did you try the 1050/4500 on an adapter, on the TF manifold?
The TF intake 1050/4150 combo was 5hp better than the unported M1/4500 combo?
