any1 use piston Part Number: UEM-KB278030 #203675
01/25/09 09:32 AM
01/25/09 09:32 AM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
in a 440 stock stroke.it is a quench dome with valve reliefs.it has a 2.050 CH,.200 dome.trying to pick a piston for Milan in the Q&A section for a max TQ motor on pump Gas.
Part Number: UEM-KB278030-8
Bore (in): 4.350 in.
Bore (mm): 110.490mm
Piston Style: Step head, with a trough
Piston Material: Hypereutectic aluminum
Compression Distance (in): 1.992 in.
Dome Height (in): 0.200 in.
Piston Head Volume (cc): -5.00cc
Wrist Pin Style: Press-fit or floating
Pin Diameter (in): 1.094 in.
Piston Ring Thickness: 5/64 in. x 5/64 in. x 3/16 in.
Quantity: Sold as a set of 8.
Notes: 0.200 inch quench dome height. Piston gram weight 775g, pin gram weight 190g.
Pistons, Hypereutectic, Step, 4.350 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring, Big Block Mopar, Set of 8
link to info at KB
http://kb-silvolite.com/performance.php?action=details&P_id=27
Re: any1 use piston Part Number: UEM-KB278030 [Re: blownzoom440] #203676
01/25/09 03:34 PM
01/25/09 03:34 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I use that piston, but 4.360". It's holding up well. That being said I think I'm on borrowed time and worry about it when I go through the traps at 7000!
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: any1 use piston Part Number: UEM-KB278030 [Re: Dave_S] #203677
01/25/09 03:49 PM
01/25/09 03:49 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if your going to use that piston with iron heads the dome will have to be machined. the kb184 will yeild the same compression without piston machining.
Re: any1 use piston Part Number: UEM-KB278030 [Re: lewtot184] #203678
01/25/09 04:12 PM
01/25/09 04:12 PM
ELYRIA,OH
ELYRIA,OH
i will have yo look at that 1 .will give quench also?
http://kb-silvolite.com/performance.php?action=details&P_id=26
that piston only has .140 dome and .075 in the hole and the other is .090 and .200 dome and maybe more V/P clearence.
Re: any1 use piston Part Number: UEM-KB278030 [Re: Dave_S] #203679
01/25/09 04:37 PM
01/25/09 04:37 PM
ELYRIA,OH
ELYRIA,OH
how much cam did you have and P/V clearence?
Re: any1 use piston Part Number: UEM-KB278030 [Re: blownzoom440] #203680
01/25/09 05:05 PM
01/25/09 05:05 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the kb catalog states that the 278 will need the domes machined. i use 184's in both my 440's.
Re: any1 use piston Part Number: UEM-KB278030 [Re: lewtot184] #203681
01/25/09 05:31 PM
01/25/09 05:31 PM
ELYRIA,OH
ELYRIA,OH
thanks for the info!what was the quench distance to the chamber? what head gasket?
Re: any1 use piston Part Number: UEM-KB278030 [Re: blownzoom440] #203682
01/25/09 09:48 PM
01/25/09 09:48 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
sorry, i'm not sure if your asking about my 184 piston set-up or if kb gives a spec for 278's. all kb stated quench clearances are .040. thats the mean dimension i've used on both my 440s with iron heads. one engine has .017 steel shims and the other has fel-pro 8519's, .039 thick. the 278 and 184 piston are the same, pin heigth, valve reliefs, with the exception of the quench dome heigth. the 184 when installed at .040 quench clearance has loads of valve relief and about 9.3:1 compression. the 278 installed at .040 quench clearance without machineing the dome will have a compression ratio close to 8.75:1 and a little more piston to valve relief.
Re: any1 use piston Part Number: UEM-KB278030 [Re: blownzoom440] #203683
01/25/09 10:20 PM
01/25/09 10:20 PM
Dave_S Offline
Dave_S  Offline
the cam has .587 lift, duration is 268 @ .050 and I have in excess of .125" PV clearance.
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: any1 use piston Part Number: UEM-KB278030 [Re: Dave_S] #203684
01/26/09 05:18 AM
01/26/09 05:18 AM
ELYRIA,OH
ELYRIA,OH
thanks guys !that very helpfull information.
