Originally Posted By Dean_Kuzluzski
Sell them to a boater. They'll get you plenty of $$ for a better set.
Otherwise, you'll overheat them, crack them, scrap them and then end up buying better headers after all.
Unless they are really thin I doubt he will crack them.
If that side wall is the same all the way down he should be good to go.
- Stu Harmon
