I do the alignment myself
so thats no big deal.. right now I have too much
caster on the right wheel
^^^Mr.P how hard is this?^^^
Real easy with struts and a inclineometer(I
use a magnetic digital one) and a tape measure
for the toe... this is really one of the only
times I wish I had a platform hoist... but I set
it up on blocks so its at ride height but up on
blocks so I can get my base numbers.. then its just
move the heim joints on the lower arm to get my 6*
caster and 0 camber.. I like about 1/32 to 1/16 toe
in.. I have to borrow the wife to have her sit in the
seat while I get the base numbers and when I think its
done to re-check
EDIT
I KNOW my shop floor is level from when I built
the shop.. I used a transit when I layed it out
and after it was done I poured water on it and
used levels and the transit to verify it was
