Re: New Best...now I need a chute.
[Re: an8sec70cuda]
#2033258
03/17/16 05:16 PM
03/17/16 05:16 PM
Posts: 2,937 A shed in England
Tig
A shed in England
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Good Job Chip!
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: ]
#2033277
03/17/16 05:44 PM
03/17/16 05:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When you do your chute mount, have it so the whole thing is removeable.. one bolt and slid it out(grade 8 bolt).. it should be on the CG of the car so it doesnt pull the back of the car up or down ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: an8sec70cuda]
#2033290
03/17/16 06:02 PM
03/17/16 06:02 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Dragula...it's on 295-65 M/T drag radials, same as I've run for years. I took the 275-60 M/T pros off b/c I thought they looked too small on the car. Just didn't look right to me. It sucks though b/c a lot of the street car races around here allow no bigger than a 28" tall tire...so now I'm not legal. Oh well.
Thanks again yall.
[Re: an8sec70cuda]
#2033310
03/17/16 06:40 PM
03/17/16 06:40 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Man that is so freakin awesome Chip! Congrats! As fast as you're going I'm glad you're gonna spend some dough on safety equipment. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: an8sec70cuda]
#2033406
03/17/16 09:51 PM
03/17/16 09:51 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Shot of the refurbished Darlington Dragway. Track was crowded, so I loaded it up and came home. Real nice, Chip. Congrat's man. Uh... I don't see anybody. How do we know it really went that fast? ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: an8sec70cuda]
#2033407
03/17/16 09:51 PM
03/17/16 09:51 PM
Posts: 4,848 Memphis
HemiRick
Memphis
We met when you came to Memphis, for the Hot Rod was it Drag week way back when, glad to see you just makin that thing faster. My Hemi is gonna go back in its Charger this spring.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: an8sec70cuda]
#2033643
03/18/16 10:16 AM
03/18/16 10:16 AM
an8sec70cuda
ProSport...thanks! I don't mind the chute...always wanted a street car w/ a chute on the back of it, lol. The diaper is gonna be a PITA though.
sgcuda...I got there early b/c they were expecting a big crowd. There were cars backed up down both sides of 151 waiting to get in from 7:00-9:00. Haven't seen a crowd out there like that in a long time! It's a whole different track than it was the last time you saw it.
HemiRick...yessir, I remember meeting you! It was the Pump Gas Drags, not Dragweek.
[Re: an8sec70cuda]
#2033949
03/18/16 05:56 PM
03/18/16 05:56 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Good runs Chip. You are going to have to work on the frontend rise. Don't know what you have going on, but it may be as simple as tightening the front and rear shocks, or you may have to put some weight on the nose. And while many think it's the opposite, sometimes getting after the car harder and quicker will keep the front down.
Depending on how your cars leaves, the delay on the nitrous could be when the car has "settled" a bit and the nitrous hit "bounces" the front back in the air a little. If it leaves wheels up, carries it there and then the nitrous pushes it further up, probably going to take nose weight to fix it or figure out how to keep the fronts on the ground period, or at least closer to ground.
Ours rarely gets higher than this unless I miss the setup
[Re: Monte_Smith]
#2035604
03/21/16 10:36 AM
03/21/16 10:36 AM
an8sec70cuda
Thanks yall!
cudarex...I'm using C12 when spraying it.
Monte...It launches wheels up on motor (see pic below), then gets higher when the nitrous comes in. I started at .3 delay and then went to .2 delay w/ no other changes. It def. got higher bringing it in quicker, but I think I may be able to keep it down by tightening the front shocks. That's what I did after my first big wheelstand w/ the .3 delay, along w/ removing an inch of travel. I'll just have to try it and see. I am footbraking, so the delay on the nitrous after the WOT switch engages may be a bit lazy.
The pic below was my first pass.
I have a video of my 2nd pass up on my facebook page BTW.
[Re: an8sec70cuda]
#2035958
03/21/16 08:23 PM
03/21/16 08:23 PM
Posts: 4,078 Mo.
racerx
Mo.
How much you spraying and what front shocks are you running?
[Re: an8sec70cuda]
#2036311
03/22/16 10:39 AM
03/22/16 10:39 AM
an8sec70cuda
racerx...somewhere around 225 I guess? A pair of 65 jets in an old NOS Doublecross plate. Supposed to be 250 according to most jet charts, but Monte says it's less. Front shocks are D/A Vikings.
Monte_Smith...I think it has around 4.5" now. It used to have an inch more, but I shortened it up. I was thinking I'd tighten up the shocks first and see how the car reacts and then take travel away if that doesn't do enough?
WHITEDART...Thank you sir!
