Re: Best sealing Trans pan for race car? [Re: Streetwize] #2031761
03/15/16 04:56 PM
03/15/16 04:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
RTV
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2031783
03/15/16 05:31 PM
03/15/16 05:31 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Have had great success using the factory gasket on 46rh, 46re, 42rh, 727, and 904s...On race cars using the Summit 904 cast aluminum pans...
Tony
70 AARCuda Vitamin C
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2031797
03/15/16 06:02 PM
03/15/16 06:02 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Been using a metal pan I got from A&A at the Nats back in 2001 or 2002 w/the same reusable gasket. He sold them as a pkg then. Deep pan, spacer and re-usable gasket. Never had a leak.
Ok
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2031864
03/15/16 08:32 PM
03/15/16 08:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By Streetwize
If Superformance wants to send me enough to make a pan gasket..... "I'm your Huckleberry!"
I'll bet most MP steel pans leak between the middle 2 front holes, I'm thinking about just making a 1/4" thick steel bar "straddle Plate" and use longer bolts. If it has the slightest bow it's a clamping issue.
I can assist you with that request.... callme
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2031869
03/15/16 08:44 PM
03/15/16 08:44 PM
JCFcuda Online content
JCFcuda  Online Content
Another vote for the Moroso gasket it's a really nice piece
Re: Best sealing Trans pan for race car? [Re: roadhazard] #2032211
03/16/16 09:44 AM
03/16/16 09:44 AM
moparx Offline
moparx  Offline
how hard is that material to cut ? i would feel better using the factory plastic gasket if the sealing ribs were lots bigger, but maybe just cut my own or wait until the "proto typing"[biggrin] is done.
beer
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2032226
03/16/16 10:12 AM
03/16/16 10:12 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Several years ago I bought a deep steel pan from Mancini, it was just like the factory pan on my 93 Dakota. I also bought the factory rigid gasket and it always weeped. Now I buy my gasket/filters from Advance Auto Parts, the gasket is rubber and seals well with the steel pan.
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2032227
03/16/16 10:15 AM
03/16/16 10:15 AM
an8sec70cuda Offline
I never had any luck w/ the steel pans. They always leaked.
I've had the thick cast aluminum pans ever since. My old 727 had one of the factory reusable plastic gaskets on it. Reused it a few times and had no leaks. Then that trans exploded on the starting line in 2008...so that gasket is no longer w/ us.
Both of my current 727s have a regular cork gasket on them now. No leaks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best sealing Trans pan for race car? [Re: moparx] #2032238
03/16/16 10:31 AM
03/16/16 10:31 AM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Roadhazard
Tried to PM you but it said your mailbox is over the limit.
I'm definitely up for getting a piece of the material to make a pan gasket from you. need it kinda quick though.
thanks!
Bobby
WIZE
In Car:
Re: Best sealing Trans pan for race car? [Re: moparx] #2032275
03/16/16 11:37 AM
03/16/16 11:37 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
beer
It cuts real nice and clean.
When I make a gasket and have the pattern all drawn out on the material the first step is cut all the bolt holes with the proper sized punch. Then I'll cut out the center with a sharp utility knife. I cut about 1/2 way through the material on the 1st lap then the rest of the way on the 2nd lap, makes it easier to follow the line precisely. Then I'll cut the outer portion with a pair of scissors. A nice piece of MDF plywood on a solid surface makes things easier also.
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2032276
03/16/16 11:39 AM
03/16/16 11:39 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Roadhazard
thanks!
Bobby
I'll try and clean it out, sorry.
Your best bet is to call callme me
Re: Best sealing Trans pan for race car? [Re: roadhazard] #2032306
03/16/16 12:18 PM
03/16/16 12:18 PM
Weddington, N.C.
Weddington, N.C.
What ever happened to the steel/Grey Ribbed Silicon OEM Trans gaskets Mopar used to sell? (the ones like the later model LA Valve Covers). They always sealed like a drum on anything.
WIZE
In Car:
Re: Best sealing Trans pan for race car? [Re: roadhazard] #2032500
03/16/16 05:24 PM
03/16/16 05:24 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Only experience is with the 727
Can't beat a cast pan with machined surfaces shruggy
This one's a TCI
I love your engine oil checking system, simple & accurate, but hardly convenient.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Best sealing Trans pan Gasket for race car? [Re: Streetwize] #2032823
03/17/16 12:47 AM
03/17/16 12:47 AM
Az
Crizila Offline
Crizila  Offline
Az
Cascade makes a molded, reusable rubber gasket. Bullet proof. Don't leak.
Fastest 300
