Page 2 of 3 1 2 3
Re: Dana for Handling/Protouring? [Re: challenger70] #2032828
03/17/16 12:52 AM
03/17/16 12:52 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
If/when you decide to become real serious, ie - competition level - you'll want to lose all the weight possible... so, thumbs down on the Dana... too heavy. A well-built 8-3/4 will always get the job done. Dana's are awesome in strength and appearance, but they're overkill with the extra weight. Further, changing the center-sections on an 8-3/4 is quick and easy if you have different tracks that can justify different gear ratios... or even the simple chore of just trying different gears at different tracks.
Re: Dana for Handling/Protouring? [Re: BigBlockMopar] #2032840
03/17/16 01:10 AM
03/17/16 01:10 AM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
Originally Posted By BigBlockMopar
If you do want to spend that extra Grant, why not get an aluminium carrier-housing for the 8-3/4"?
Cause then I still have an 8.75, I don't want to worry with the 4 speed and sticky slicks or drag radials if I ever drag race the car. Buy once cry once...
If I had the skills and equipment and time I would go the home brew/junkyard route and by the time I paid someone to do it right I am back at the cost of a brand new improved Dana.
I would never put a Ford diff in my Mopar, sorry...might be stupid and bullheaded but my Mopars will stay all Mopar or at least oem style rear..
I appreciate all the input so far, thanks everyone!
Re: Dana for Handling/Protouring? [Re: challenger70] #2032877
03/17/16 02:15 AM
03/17/16 02:15 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I should have NEVER wasted my time & money on my 8 3/4 , another lesson learned.
Re: Dana for Handling/Protouring? [Re: 72Swinger] #2032898
03/17/16 03:09 AM
03/17/16 03:09 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Originally Posted By 72Swinger
Originally Posted By astjp2
I would just get a junkyard 60, have Dutchman narrow it and provide shafts, use the torino ends, explorer brake kit from a jeep place, find a set of true Spicer 3.54 gears, diff of your choice (prefer power lok) and put it together, should cost about $1200 plus your labor. Tim
I have considered this to, have one in the backyard, but those truck axles have 3/8" wall tube, or thicker, and after you buy ends $100, pay to have them put on $2-250, have it cleaned and painted $40? An S60 housing with billet side adjusters and choice of ends at $665 is pretty attractive.
Mine was 1/2" wall tube, a bare narrow housing was 68#, shipped by Dutchman in a cardboard box. Narrowing was $400 with the torino ends. The shafts are about the same price from most vendors. Brakes were $150 and I got the calipers from a salvage yard for $40. I also put in a 10.5" ring gear and a rebuilt power lock. I spent about 6 months collecting parts and building it. If you want instant gratification, do the strange, if you like to build...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana for Handling/Protouring? [Re: challenger70] #2032901
03/17/16 03:29 AM
03/17/16 03:29 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The truck housing are just heavy, I need to find out what an S60 housing weighs.
Mopar to the bone!!!
Re: Dana for Handling/Protouring? [Re: challenger70] #2032915
03/17/16 04:26 AM
03/17/16 04:26 AM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Ford 8.8 with factory rebuild able LSD and disk brakes is the way to go these days.
Re: Dana for Handling/Protouring? [Re: CSK] #2032987
03/17/16 11:07 AM
03/17/16 11:07 AM
Berwyn, IL
Berwyn, IL
That is the rabbit hole I went down too, I am avoiding that again...
Re: Dana for Handling/Protouring? [Re: challenger70] #2033316
03/17/16 06:51 PM
03/17/16 06:51 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Care to elaborate? I thought the same thing about cost when building mine. After I did it, I was only a couple hundred dollars shy of having Dr Diff building me a Dana 60.
Re: Dana for Handling/Protouring? [Re: MuuMuu101] #2033645
03/18/16 10:21 AM
03/18/16 10:21 AM
Berwyn, IL
Berwyn, IL
Exactly! by the time I got axles, tru-track, ect... I wasn't that far from a new Dana, and I still had an 8.75. I am talking about the 8.75 in my Challenger.
Re: Dana for Handling/Protouring? [Re: challenger70] #2034010
03/18/16 07:56 PM
03/18/16 07:56 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I run a Dana S60 from Cass with no regrets. Sold the stock 8 3/4 before I owned 2 of them.... by the time you buy all new parts I figured I might as well get the Dana and forget about it.
Re: Dana for Handling/Protouring? [Re: challenger70] #2034014
03/18/16 08:02 PM
03/18/16 08:02 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
I'm now building an 60 with S-Trac, I built two 8.75's, spent money buying housings and centres, only to be very disappointed with the rattley Eaton TruTrac in both builds, Cass told me from the get go, just get a Dana.
Re: Dana for Handling/Protouring? [Re: crash520] #2034226
03/19/16 01:04 AM
03/19/16 01:04 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
rattley truetrac?
Re: Dana for Handling/Protouring? [Re: challenger70] #2034823
03/20/16 01:29 AM
03/20/16 01:29 AM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Re: Dana for Handling/Protouring? [Re: challenger70] #2034862
03/20/16 03:12 AM
03/20/16 03:12 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
This will be for my Charger big block, 4-speed, XV level 1 suspension.
I've busted way to many 8 3/4 rears over the decades on the track and street on B and E body cars, they aren't worth the effort/expense, I'll trade the weight of the 8 3/4 for reliability/stoutness of the DANA
My Charger is running a Dana 60, 4 wheel disc, 7/8" rear bar, 4:10 gears, 440/6, Keisler TKO 600 .064 OD, and yes, Green Bearings going on 12+ years, 40K+ hard miles, many different tracks around the country, Power Tours, street driven, etc with no failures, I beat the piss out of my cars, and expect parts to take it
Re: Dana for Handling/Protouring? [Re: challenger70] #2034951
03/20/16 11:36 AM
03/20/16 11:36 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
So you have done road coarse kind of stuff with the green bearings? I know they are fine on the street I have them in the Dana in my dart.
Re: Dana for Handling/Protouring? [Re: DAYCLONA] #2034954
03/20/16 11:40 AM
03/20/16 11:40 AM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Weird. I couldn't get 6k miles out of a set of green bearings in my Dana to save my life. I used to keep a spare set so that if I was at an event I could put on a fresh set if I felt they were getting too loose. They became a regular, annoying service item. I ended up selling both my Danas for Nodular, full floating Ford 9" and Ford 8.8s. the 9" is unreal compared to any of them but the 8.8's are a step up from the Dana and 8.75.
Re: Dana for Handling/Protouring? [Re: challenger70] #2035078
03/20/16 02:44 PM
03/20/16 02:44 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
This is an ancient picture of my strange S 60 in my 1970 Dart. A great decision.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Dana for Handling/Protouring? [Re: crash520] #2035107
03/20/16 03:17 PM
03/20/16 03:17 PM
Berwyn, IL
Berwyn, IL
hmmm I was planning on the trutrac in my future dana, I love it in my 8.75. Is there a special bearing configuration I want or are the stock style bearings ok for side loads? What would be diff of choice?
Thanks for getting this back on track, I didn't want this to be a Dana vs. 8.75 argument.
Re: Dana for Handling/Protouring? [Re: challenger70] #2035175
03/20/16 05:38 PM
03/20/16 05:38 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
I don't believe there is anything wrong with the 8.75, pending your HP and intended use they are fine, I loved the Trutrac operation in mine and would have stayed with the 8.75, but the noise was the issue, I can run either tapered or roller bearings in the Dana. I like tapered but might run roller as it's just a low mile street/strip car
Re: Dana for Handling/Protouring? [Re: challenger70] #2035377
03/20/16 10:39 PM
03/20/16 10:39 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Go with the Torino bearings, they are WAY more stout than anything that mopar put out back in the day. I would also do a powerlock. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Page 2 of 3 1 2 3
