Re: 6.4 hemi, what would i be getting myself into?
[Re: mopar_man619]
#2040257
03/28/16 03:37 AM
03/28/16 03:37 AM
Posts: 340 San Diego, CA
mopar_man619
San Diego, CA
well probably not getting the 6.4 i thought i was. still in the market for a 6.1 or 5.7. wanna pull it out of a wrecked car from the salvage auction, as i feel this will be the best route. still going in an a body (67 valiant) with factory steering. what do you guys suggest as far as 5.7 or 6.1. want a turbo down the road. street/strip.
1967 Plymouth Valiant Gen III Hemi 11.42@119 youtube.com/moparman619
[Re: mopar_man619]
#2041336
03/29/16 06:58 PM
03/29/16 06:58 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
megasquirt can do VVT and it is amazing.
They offer a base cal and a plug 'n' play harness for 6.4Ls, too. I have 2 running but not 100% tuned yet (spring here, will hit a dyno soon). a-e-a.com .
F&B offers a bolt-on throttle body that flows more air and is cable operated, I designed it.
No major problems into A-body, shorten the steering col jacket a bit, milodon pan, TTi headers and mounts, remote filter.
Rick
[Re: Rick_Ehrenberg]
#2041354
03/29/16 07:28 PM
03/29/16 07:28 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
That site is a front page only and hasn't been updated since 2004. That doesn't encourage me to spend money with them.
[Re: mopar_man619]
#2065655
05/02/16 12:48 AM
05/02/16 12:48 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
also anybody with experience, i would be able to get this into a valiant with the stock k frame. i have read it will be a tight fit but will work with the correct oil pan. I got a 5.7 Hemi core motor to fit in a 1965 Dodge Dart by using Jeep SRT exhaust manifolds, and coilover shocks to allow for the exhaust. I built a rack and pinion setup out of a stock K frame to take care o steering. The manifolds just make it in the early A, so there ought to be a little extra room in a 67 or newer. That is a truck oil pan , and I plan to shorten it and add back the volume with side buckets.
#2065661
05/02/16 01:06 AM
05/02/16 01:06 AM
Posts: 361 Canada
onig
Canada
Rick
What is the part # for this throttle body? I checked the site but could not find it.
69 Dart
[Re: gregsdart]
#2067623
05/05/16 09:08 AM
05/05/16 09:08 AM
mopar_man619
San Diego, CA
if you were running torsion bars would the jeep manifolds clear?
[Re: onig]
#2072016
05/12/16 01:23 PM
05/12/16 01:23 PM
Posts: 2,956 GA
roadrunninMark
GA
Rick
What is the part # for this throttle body? I checked the site but could not find it. Rick, also does this allow you to use the NAG1 trans since you are not using the electronic gas pedal? Or do you need to use that for the trans?
