Re: Dana for Handling/Protouring?
[Re: challenger70]
#2032828
03/17/16 12:52 AM
03/17/16 12:52 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
If/when you decide to become real serious, ie - competition level - you'll want to lose all the weight possible... so, thumbs down on the Dana... too heavy. A well-built 8-3/4 will always get the job done. Dana's are awesome in strength and appearance, but they're overkill with the extra weight. Further, changing the center-sections on an 8-3/4 is quick and easy if you have different tracks that can justify different gear ratios... or even the simple chore of just trying different gears at different tracks.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: BigBlockMopar]
#2032840
03/17/16 01:10 AM
03/17/16 01:10 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
If you do want to spend that extra Grant, why not get an aluminium carrier-housing for the 8-3/4"? Cause then I still have an 8.75, I don't want to worry with the 4 speed and sticky slicks or drag radials if I ever drag race the car. Buy once cry once... If I had the skills and equipment and time I would go the home brew/junkyard route and by the time I paid someone to do it right I am back at the cost of a brand new improved Dana. I would never put a Ford diff in my Mopar, sorry...might be stupid and bullheaded but my Mopars will stay all Mopar or at least oem style rear.. I appreciate all the input so far, thanks everyone!
[Re: challenger70]
#2032877
03/17/16 02:15 AM
03/17/16 02:15 AM
Posts: 2,874 Pattison Texas
CSK
Pattison Texas
I should have NEVER wasted my time & money on my 8 3/4 , another lesson learned.
[Re: 72Swinger]
#2032898
03/17/16 03:09 AM
03/17/16 03:09 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would just get a junkyard 60, have Dutchman narrow it and provide shafts, use the torino ends, explorer brake kit from a jeep place, find a set of true Spicer 3.54 gears, diff of your choice (prefer power lok) and put it together, should cost about $1200 plus your labor. Tim I have considered this to, have one in the backyard, but those truck axles have 3/8" wall tube, or thicker, and after you buy ends $100, pay to have them put on $2-250, have it cleaned and painted $40? An S60 housing with billet side adjusters and choice of ends at $665 is pretty attractive. Mine was 1/2" wall tube, a bare narrow housing was 68#, shipped by Dutchman in a cardboard box. Narrowing was $400 with the torino ends. The shafts are about the same price from most vendors. Brakes were $150 and I got the calipers from a salvage yard for $40. I also put in a 10.5" ring gear and a rebuilt power lock. I spent about 6 months collecting parts and building it. If you want instant gratification, do the strange, if you like to build...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: challenger70]
#2032901
03/17/16 03:29 AM
03/17/16 03:29 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The truck housing are just heavy, I need to find out what an S60 housing weighs.
Mopar to the bone!!!
[Re: CSK]
#2032987
03/17/16 11:07 AM
03/17/16 11:07 AM
challenger70
Berwyn, IL
I should have NEVER wasted my time & money on my 8 3/4 , another lesson learned. That is the rabbit hole I went down too, I am avoiding that again...
[Re: challenger70]
#2033316
03/17/16 06:51 PM
03/17/16 06:51 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I should have NEVER wasted my time & money on my 8 3/4 , another lesson learned. That is the rabbit hole I went down too, I am avoiding that again... Care to elaborate? I thought the same thing about cost when building mine. After I did it, I was only a couple hundred dollars shy of having Dr Diff building me a Dana 60.
[Re: MuuMuu101]
#2033645
03/18/16 10:21 AM
03/18/16 10:21 AM
challenger70
Berwyn, IL
I should have NEVER wasted my time & money on my 8 3/4 , another lesson learned. That is the rabbit hole I went down too, I am avoiding that again... Care to elaborate? I thought the same thing about cost when building mine. After I did it, I was only a couple hundred dollars shy of having Dr Diff building me a Dana 60. Exactly! by the time I got axles, tru-track, ect... I wasn't that far from a new Dana, and I still had an 8.75. I am talking about the 8.75 in my Challenger.
[Re: crash520]
#2034226
03/19/16 01:04 AM
03/19/16 01:04 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I'm now building an 60 with S-Trac, I built two 8.75's, spent money buying housings and centres, only to be very disappointed with the rattley Eaton TruTrac in both builds, Cass told me from the get go, just get a Dana. rattley truetrac?
[Re: challenger70]
#2034862
03/20/16 03:12 AM
03/20/16 03:12 AM
Posts: 18,160 Mass
DAYCLONA
Mass
This will be for my Charger big block, 4-speed, XV level 1 suspension.
I've busted way to many 8 3/4 rears over the decades on the track and street on B and E body cars, they aren't worth the effort/expense, I'll trade the weight of the 8 3/4 for reliability/stoutness of the DANA My Charger is running a Dana 60, 4 wheel disc, 7/8" rear bar, 4:10 gears, 440/6, Keisler TKO 600 .064 OD, and yes, Green Bearings going on 12+ years, 40K+ hard miles, many different tracks around the country, Power Tours, street driven, etc with no failures, I beat the piss out of my cars, and expect parts to take it
[Re: DAYCLONA]
#2034954
03/20/16 11:40 AM
03/20/16 11:40 AM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
I've busted way to many 8 3/4 rears over the decades on the track and street on B and E body cars, they aren't worth the effort/expense, I'll trade the weight of the 8 3/4 for reliability/stoutness of the DANA My Charger is running a Dana 60, 4 wheel disc, 7/8" rear bar, 4:10 gears, 440/6, Keisler TKO 600 .064 OD, and yes, Green Bearings going on 12+ years, 40K+ hard miles, many different tracks around the country, Power Tours, street driven, etc with no failures, I beat the piss out of my cars, and expect parts to take it Weird. I couldn't get 6k miles out of a set of green bearings in my Dana to save my life. I used to keep a spare set so that if I was at an event I could put on a fresh set if I felt they were getting too loose. They became a regular, annoying service item. I ended up selling both my Danas for Nodular, full floating Ford 9" and Ford 8.8s. the 9" is unreal compared to any of them but the 8.8's are a step up from the Dana and 8.75.
[Re: challenger70]
#2035078
03/20/16 02:44 PM
03/20/16 02:44 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
This is an ancient picture of my strange S 60 in my 1970 Dart. A great decision.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: crash520]
#2035107
03/20/16 03:17 PM
03/20/16 03:17 PM
challenger70
Berwyn, IL
I'm now building an 60 with S-Trac, I built two 8.75's, spent money buying housings and centres, only to be very disappointed with the rattley Eaton TruTrac in both builds, Cass told me from the get go, just get a Dana. hmmm I was planning on the trutrac in my future dana, I love it in my 8.75. Is there a special bearing configuration I want or are the stock style bearings ok for side loads? What would be diff of choice? Thanks for getting this back on track, I didn't want this to be a Dana vs. 8.75 argument.
[Re: challenger70]
#2035377
03/20/16 10:39 PM
03/20/16 10:39 PM
astjp2
Utah and Alaska
Go with the Torino bearings, they are WAY more stout than anything that mopar put out back in the day. I would also do a powerlock. Tim
