Predator Engine
#2029001
03/11/16 03:26 AM
03/11/16 03:26 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
What distributors are you guys using? I know there is the offset one offered by Indy and if you run a Jesel belt drive you can run the belt drive distributor. Let me know what you guys are using.
Re: Predator Engine
[Re: Biginchmopar]
#2029004
03/11/16 03:50 AM
03/11/16 03:50 AM
Posts: 1,050 San Jose Ca.
boatracer572
San Jose Ca.
What distributors are you guys using? I know there is the offset one offered by Indy and if you run a Jesel belt drive you can run the belt drive distributor. Let me know what you guys are using. I use the jesel front drive, MSD and Mallery also make front drives that can be used with a little modification.....
Re: Predator Engine
[Re: Biginchmopar]
#2029007
03/11/16 04:04 AM
03/11/16 04:04 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Nice engine mate !!! What sort of power from that 1000+ ?
1963 Plymouth Max Wedge 1971 Barracuda
Re: Predator Engine
[Re: Biginchmopar]
#2029009
03/11/16 04:18 AM
03/11/16 04:18 AM
Posts: 19,563 Las Vegas
Al_Alguire
Las Vegas
Jesel front drive, set it and forget it. The MSD is a nice piece too but is really large in comparison.
Re: Predator Engine
[Re: Biginchmopar]
#2029237
03/11/16 03:37 PM
03/11/16 03:37 PM
Biginchmopar
Carson City, Nevada
Do any of you guys have a deal with Jesel? The best price I can find on the kit (Belt drive and distributor) is $2090.00.
I need the raised cam (.250") belt drive and the distributor with mount.
Re: Predator Engine
[Re: Biginchmopar]
#2029642
03/12/16 03:27 AM
03/12/16 03:27 AM
Al_Alguire
Las Vegas
The raised cam belt drive is the killer for sure. Been there done that a few times. I just order from Jesel
Re: Predator Engine
[Re: Biginchmopar]
#2030111
03/13/16 04:14 AM
03/13/16 04:14 AM
boatracer572
San Jose Ca.
Al and Boatracer,
Does your motor plate get in the way of mounting the belt drive distributor on the Jesel deal? No.... I have a 3/8" motor plate, and the front drive dist. clears fine
