Re: ATF in TF727?
[Re: fed]
#2028283
03/10/16 01:39 AM
03/10/16 01:39 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
If I make the switch to John deer hydraulic fluid, can I just pull the trans and drain it and drain the converter? or does it have to be a empty fresh rebuild trans and converter?
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: ATF in TF727?
[Re: slammedR/T]
#2028292
03/10/16 01:48 AM
03/10/16 01:48 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I basically agree with everyone. It seems many have used the type they like for years and have had good luck with it. Myself I use the Mopar ATF+4 but since I was a tech at a Dodge dealer for 24 years and did auto trans work along with the other work I did I have a small stock of the ATF+4 since we usually would charge out an extra qt of fluid on warranty jobs and us guys who did trans work always had some extra. So it is good on my pocket to use the ATF+4 and its worked great for me for many years. But I would have no problem using some of the others mentioned on here either. Ron
Re: ATF in TF727?
[Re: cdwmotorsports]
#2028313
03/10/16 02:24 AM
03/10/16 02:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The one reason I run the type F is the guys in the trans lab at Chrysler... I had plenty of friends in there and asked this question when I started racing... ALL of them said F so I did.. some of them were racers with quick cars... and the first trans that I used was built by one of those guys and again he said type F.. but this is my junk 727 EDIT this is still a trans from the 60s so whats so different...... JMO on this.. since I dont race big dollar stuff
Re: ATF in TF727?
[Re: slammedR/T]
#2028335
03/10/16 03:38 AM
03/10/16 03:38 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If I make the switch to John deer hydraulic fluid, can I just pull the trans and drain it and drain the converter? or does it have to be a empty fresh rebuild trans and converter? Drain it, change it and it will be fine. So you asked when you started racing Mr P..........how long ago was that.....LOL!!! Have you asked since
Re: ATF in TF727?
[Re: MR_P_BODY]
#2028337
03/10/16 03:49 AM
03/10/16 03:49 AM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
Seems as though, the correct fluid would be what the different friction material requires. They have different coefficient of friction, just like the fluid. Don't expect to find any quick info, I've searched on and off for years, and give up. Just like the 2 hours I wasted today. I use Raybestos Blue Plates and type F. I can read the lettering after 250 passes, with the correct clearance. If and when I know what Raybestos recommends, I'll consider changing.
Re: ATF in TF727?
[Re: Monte_Smith]
#2028340
03/10/16 03:57 AM
03/10/16 03:57 AM
MR_P_BODY
If I make the switch to John deer hydraulic fluid, can I just pull the trans and drain it and drain the converter? or does it have to be a empty fresh rebuild trans and converter? Drain it, change it and it will be fine. So you asked when you started racing Mr P..........how long ago was that.....LOL!!! Have you asked since I started racing a long time ago.. most likely when you were young... but the last time I asked... about 8 years ago.. did they change the 727 since then.. if so I will look at hyd fluid.... again ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: ATF in TF727?
[Re: Monte_Smith]
#2028438
03/10/16 12:04 PM
03/10/16 12:04 PM
Posts: 7,506 Az
Crizila
Az
I don't doubt anything anyone says based on years of experience, but when it comes to what is "best" for anything is a very random question and has no clear cut answer. If you have been building race trans for 30 years, always used Type F and never had many problems, sure, you can claim that the best. Same with cams, intakes or anything else............but this is 2016. Hard to fathom that a very basic oil from the 60s and earlier, is the absolute BEST fluid you can put in a race trans. Why aren't we all still running straight 30W Quaker State for oil. Or "mushroom" cams, pinion snubbers, casler tires or anything else that was the BEST in the 60s.
Like I said, Type F will work and obviously many still use it. I only said there was better fluid and I believe that "edited by Monte_Smith" - come on Monte, don't hold back. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
Fastest 300
Re: ATF in TF727?
[Re: fed]
#2028824
03/10/16 10:13 PM
03/10/16 10:13 PM
Monte_Smith
North Alabama
This is pretty simple. Automatic transmissions, regardless of make work the same. There are some bearings and some clutch packs. You have to lube the hard parts and the clutch packs still "bite". Years ago, you had Dextron and Type F basically. Dextron had friction modifiers in it, Type F didn't. So in a race trans, it was felt Type F would let the clutches grab better. In reality they obviously BOTH worked just fine but some builders preferred one fluid or the other.
Today, as with everything else, we have learned a lot. Parts are more precise, clutch material is better, coated steels and all sorts of other things to make the trans work better. We also have much better fluid. The lubricity is better, but so is the "bite". How do you do that........additives. So as a result, Modern fluids are much more refined. They let your "driver" pickup truck shift without you even feeling it, by slipping the clutches but not burning them, and when it's needed, can still lock up firmly to tow that trailer and lock the converter up. You slip the clutches much with old type fluid and the heat scorches the fluid and it's trash. New fluids are MUCH more resistant to heat, foaming, scorching and lubricity breakdown. Simply put, it's better. You want to run old school fluid because you always have and it's worked......fine. Nobody is trying to stop you. But modern fluid is simply better. In a harsh environment, like a race trans, with a loose converter(that makes heat, lots of it) small or non existent coolers, yet wanting to maintain max bite and good lube qualities. Which fluid you think is BETTER. I didn't said would work, I said BETTER.
Re: ATF in TF727?
[Re: justinp61]
#2028852
03/10/16 10:54 PM
03/10/16 10:54 PM
dartman366
Mt. Vernon, Ohio
Monty JD lists five hydraulic fluids. Which one do you you run? I would like to know this answer my self.
Re: ATF in TF727?
[Re: dartman366]
#2028885
03/11/16 12:02 AM
03/11/16 12:02 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
So when we are talking friction and gripping properties and making it last on the track, how about a trans that sees more street duty and some weekends at the track?? I have always used the Dex style but am open to change for max trans life!! Thanks. I like the fact that there are some good people here who know their stuff!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
Re: ATF in TF727?
[Re: fed]
#2028902
03/11/16 12:18 AM
03/11/16 12:18 AM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never tried it. But I may, and looking at the specs, I would use the low viscosity Hy-Gard in a normal trans like most of us run. The viscosity numbers are very close to the normal ATF+4 and Type F. The regular Hy-Gard is quite a bit thicker. Would not be surprised if that is what is used in the real high horsepower units just for that reason.
Both of the Hydrau oils are higher viscosity than normal ATF, but the Hydrau XR is close. That may be an option also for the big power cars, but it's actually made for construction and forestry equipment.
Re: ATF in TF727?
[Re: justinp61]
#2028924
03/11/16 12:59 AM
03/11/16 12:59 AM
Monte_Smith
North Alabama
Monty JD lists five hydraulic fluids. Which one do you you run? Most use Hy-Guard or the Low Viscocity Hy-Guard. The Low Viscosity is a direct swap for most ATFs, except if you read the standards is MUCH more durable and maintains viscosity better at higher temps and that's what we WANT. I would suggest the low viscosity for anybody wanting to swap. We have run regular Hy-Guard and a lot of guys with Bruno's and Lenco Drives use this. The regular Hy-Guard will generally tighter your converter up about 200-300 on the stall.
Re: ATF in TF727?
[Re: justinp61]
#2028925
03/11/16 01:00 AM
03/11/16 01:00 AM
slammedR/T
Monty JD lists five hydraulic fluids. Which one do you you run? Same question from me??
