Page 5 of 12 1 2 3 4 5 6 7 11 12
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2010316
02/12/16 01:56 AM
02/12/16 01:56 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I agree, I cant see the benefit of the hoop over the tank ? Is it there for a reason ?
That is a big lump of horse power you have there smile there is a stack of weight in a blower and hat isn't there ? I had a 8/71 with bird hat, nearly crapped my pants lifting on and off smile
1963 Plymouth Max Wedge
1971 Barracuda
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2010331
02/12/16 02:20 AM
02/12/16 02:20 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Isn't there something in the rule book on protecting the fuel cell? Seem to remember a old friend of mine had to ad some tubing around his front mounted fuel cell to be in compliance .
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2010369
02/12/16 09:21 AM
02/12/16 09:21 AM
Parts unknown
590 Challenger Offline OP
Parts unknown
I have to have 1 1/4 bars in front of the cell, I do. I put the engine and trans in the night before together, it wasn't a big deal with the bar there and that fuel cell is a pain to get out. I should be pushing 2,000 horse with plans on stepping things up the following year. To plant the little 315 tires well, I need the chassis as stiff as possible. I don't have double frame rails I believe tieing it all together on a second level will help keep the front stiffer. I also plan on hanging the front end off it from a bar replacing the radiator support. On the inside will mount my fuel filter. Sorry but I kind of like it and am willing to give it a try
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2010450
02/12/16 01:55 PM
02/12/16 01:55 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you like it......that is all that matters, but it DOES nothing. People worry about holding the front of the car together. The MOTOR does that. Some of the nicest pro built cars in the world are pretty floppy up front with no motor. THAT is your biggest structural support. Plus, stiffness out front doesn't matter. To make big power work on a radial, it must be REALLY stiff from the mid plate back to the rear shock mounts
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2010500
02/12/16 03:27 PM
02/12/16 03:27 PM
Parts unknown
Parts unknown
Thank you for your input. I have given it much consideration before putting them in. Most modern day pro mods are switching to double frame rails to stiffen the front end. Maybe it's for another reason? Any ways a single 1 5/8 moly bar is much more solid then the factory frame rail would be. I look at it like a lever, bars close together must be strong, further away not as much. Do I need this? Maybe not, but I'm sure this 3 lbs will stiffen the front end up a ton. I will start tieing in the mid plate this weekend
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2018695
02/24/16 12:12 PM
02/24/16 12:12 PM
Parts unknown
Parts unknown
I added some ears to the 1/2 inch motor plate. Tied them in to the lower frame rail and upper frame rail. I will run some jumpers back to the lower cage structure, then tie in the top back to the dash bar. I will run a bar inside tieing the top together just inside the fire wall (so I can still access the top trany bolts)
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2024735
03/04/16 11:27 PM
03/04/16 11:27 PM
Parts unknown
Parts unknown
Loads of fun TIG-ing it in. Hope it's worth the effort. Hidden cross bar just inside the fire wall making access for the trans bolts.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2024832
03/05/16 02:21 AM
03/05/16 02:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice work................ thumbs
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2024919
03/05/16 11:29 AM
03/05/16 11:29 AM
Parts unknown
Parts unknown
Thanks, looking to add a few hundred horse this year, and a few hundred more the next year. Getting the ground work done and made room to make some Zoomies. Building the front shock mounts today, gotta hurry, spring is coming.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2024923
03/05/16 11:32 AM
03/05/16 11:32 AM
New York
polyspheric Online content
polyspheric  Online Content
New York
How do you figure that?
Boffin Emeritus
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2024934
03/05/16 12:19 PM
03/05/16 12:19 PM
Parts unknown
Parts unknown
Hmmmm, always heard that. Im assuming it's because round is much stronger, seamless, more carbon in moly (30). I'm headed to the chassis shop to have a few tubes bent right now. I'll ask them
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025042
03/05/16 03:30 PM
03/05/16 03:30 PM
Parts unknown
Parts unknown
I asked my chassis guy this morning which was stronger, a Mopar factory frame rail or a 1 5/8 moly tube. My Chassis guy didn’t get real technical, but replied probably the moly tube, Mopar factory frame rails are just stamped sheet metal…..sorry that all the info I got
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025565
03/06/16 10:17 AM
03/06/16 10:17 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Looking good Jeff! Can't wait to see it make some passes
Randy
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025775
03/06/16 04:08 PM
03/06/16 04:08 PM
Parts unknown
Parts unknown
Thanks Randy!
Making the shock mounts today, slow but making progress, first race is only about 7 weeks out. I plan on being there
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025865
03/06/16 06:57 PM
03/06/16 06:57 PM
Parts unknown
Parts unknown
I cut out the lip on the frame rail. Mounted the shock support tubes to a piece of angle iron to strengthen it. Ran a couple cross bars, it seems like it will be strong as hell
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025889
03/06/16 07:37 PM
03/06/16 07:37 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
So, with your old strut support that you were running, do you feel it was not strong enough. Were it flexing? Never seen anyone tie in the trans bell housing like this(not saying it hasn't been done before just I never seen it)interesting build. up
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025900
03/06/16 07:50 PM
03/06/16 07:50 PM
Parts unknown
Parts unknown
Thanks, I think they were fine with the inner fenders in place. After cutting them out I don't believe strong enough, let alone looking like a complete disaster. This will be stronger and much easier to work around.
I never seen a mid plate mount like this either. I'm not much of a cookie cutter kind of guy anyways. I wanted it stiffer but class rules say I can't move my firewall.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025911
03/06/16 08:02 PM
03/06/16 08:02 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
On a high HP car, the mid plate area NEEDS to be an integral part of the chassis or you will have problems. This is still just kind of "hanging out there" and has no side to side support. Those bars coming off the upper strut bars should have been ONE bar that was bent to cross top of trans and then up to other snout bar and THEN tied in to rest of chassis. Plus the mid plate is just mounted on a piece of angle hanging in the breeze off the tubing.
The TWO tubes for the shock support serves no purpose. One would have been plenty. Not trying to be critical here and I applaud anyone who takes on a project like this themselves, but some thought as to what something DOES and what you NEED it to do, needs to be taken into account before you just start welding tubing in where it LOOKS like it needs something.
At this point, car has had a lot of tubing added that doesn't DO anything.
With a "stock firewall" rule, you could have bent the loop the way I referenced, then placed that loop back against firewall or even notched and made it "part" of firewall. Some bracing would have then had mid plate basically boxed and "part" of factory firewall and structure. You could then have moved motor back a touch.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025921
03/06/16 08:12 PM
03/06/16 08:12 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Like this
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2025927
03/06/16 08:22 PM
03/06/16 08:22 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Inside car
