Re: Aluminum main caps or Billet with a girdle?
[Re: Monte_Smith]
#2025286
03/05/16 10:01 PM
03/05/16 10:01 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Personally, I don't think a short, or even medium fill hurts cooling. These motors circulate little water at the bottom of the cylinders anyway. All the heat is at the top of the bore ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I've been running a half fill on the 440 in my Roadrunner for 15 years. No issues to date.
72 Plymouth Roadrunner 11.08@123.25
[Re: Eric]
#2025918
03/06/16 08:09 PM
03/06/16 08:09 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Spoke with Mike Janis yesterday and dropped off the block. I have main studs already and I'm going with an aluminum cap. Not sure on the fill yet. Going to try to make this one last so any cam change will be just to use the same grind if this one is damaged.
5.53 @ 125 1/8th on the launch control..more left in her!
