Page 21 of 45 1 2 19 20 21 22 23 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2015701
02/19/16 10:10 PM
02/19/16 10:10 PM
AndyF Offline
AndyF  Offline
I have my new clear top valve cover mounted up on the Trick Flow heads for the next round of dyno testing.
Re: Trick Flow heads [Re: fast68plymouth] #2015732
02/19/16 11:19 PM
02/19/16 11:19 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Would like a pair of them. Nice work .
1963 Plymouth Max Wedge
1971 Barracuda
Re: Trick Flow heads [Re: AndyF] #2016027
02/20/16 01:24 PM
02/20/16 01:24 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Andy do those only fit with a non conventional distributor location?
Re: Trick Flow heads [Re: fast68plymouth] #2016038
02/20/16 01:48 PM
02/20/16 01:48 PM
AndyF Offline
AndyF  Offline
This one does. The next one I make will work with a distributor.
Re: Trick Flow heads [Re: fast68plymouth] #2018155
02/23/16 05:28 PM
02/23/16 05:28 PM
AndyF Offline
AndyF  Offline
I've heard that the low deck intake will be available by the end of the month. I'll get one on the dyno as soon as it shows up. The RB intake is available now from Summit but I haven't bought one since I don't have a standard port RB engine to use it on.
Re: Trick Flow heads [Re: fast68plymouth] #2018166
02/23/16 05:54 PM
02/23/16 05:54 PM
Wild West
M_D Offline
M_D  Offline
Wild West
Andy, how is the clear top going to be sealed to the rest of the valve cover? I can't tell if you have some sort of gasket in there and don't see any signs of an o-ring or groove.
I will/would be interesting to see in there while the engine ran.
Re: Trick Flow heads [Re: fast68plymouth] #2018241
02/23/16 07:32 PM
02/23/16 07:32 PM
AndyF Offline
AndyF  Offline
I'll get some gaskets made for it. I also have a stainless steel beauty ring that goes on the top so the bolts aren't riding on the polycarb.
Re: Trick Flow heads [Re: AndyF] #2019016
02/24/16 08:16 PM
02/24/16 08:16 PM
Washington PA
69 plymouth rnr Offline
Washington PA
This is a great thread but is there anyone who can confirm Trick Flows claims on a 440 build they claim . Or any other trick flow dyno numbers with different combos?? THANKS
Re: Trick Flow heads [Re: AndyF] #2020963
02/27/16 10:17 PM
02/27/16 10:17 PM
Wild West
M_D Offline
M_D  Offline
Wild West
Thanks for the explanation. Being able to see the valve train while running to check for proper oiling and to easily inspect it while not running makes a lot of sense to me. Especially on new engines and parts when things might need some sorting out and extra monitoring.
Re: Trick Flow heads [Re: fast68plymouth] #2021034
02/28/16 12:20 AM
02/28/16 12:20 AM
AndyF Offline
AndyF  Offline
Yeah, a lot of guys bring engines in with crappy parts on them for dyno testing and something simple like a clear valve cover can help show guys that their parts aren't any good. Some of the really cheap rocker arms don't oil properly but guys don't want to believe that the parts they bought aren't any good.
Re: Trick Flow heads [Re: fast68plymouth] #2021191
02/28/16 12:12 PM
02/28/16 12:12 PM
crabman173
crabman173
Looks like fun!
I had my hands on the Trick Flows yesterday for first time--WOW! All I can say is Happy Trails Indy!
Re: Trick Flow heads [Re: 69 plymouth rnr] #2024982
03/05/16 01:58 PM
03/05/16 01:58 PM
Idaho
LaRoy Engines Offline
Idaho
Had only one day to dink with these combinations.
Trick Flow 240, .030" over 440, stock stroke, 9.9:1 compression, 850 Mighty Demon, Edelbrock Victor and RPM intakes, Solid roller 238/242 @ .050.
Victor.....
500 lb-ft 3,300-6,100rpm
550 lb-ft 4,500-5,300rpm
562 lb-ft @ 4,800rpm
591 hp @ 5,900rpm
RPM........
500 lb-ft 3,100-5,900rpm
550 lb-ft 3,600-5,200
558 lb-ft @ 4,800rpm
575 hp @ 5,700
Re: Trick Flow heads [Re: fast68plymouth] #2024986
03/05/16 02:04 PM
03/05/16 02:04 PM
So. Burlington, Vt.
fast68plymouth Online content OP
fast68plymouth  Online Content OP
So. Burlington, Vt.
Had you run any other heads on that particular motor?
Re: Trick Flow heads [Re: fast68plymouth] #2024993
03/05/16 02:18 PM
03/05/16 02:18 PM
Idaho
Idaho
No, brand new build. Have done recent builds very similar but with cleaned up Victor heads and solid/hydraulic flat tappets.
Re: Trick Flow heads [Re: fast68plymouth] #2025000
03/05/16 02:28 PM
03/05/16 02:28 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
How much lift?
Have a great day
Iowan
"obsolete is neat"
Re: Trick Flow heads [Re: AndyF] #2033867
03/18/16 03:49 PM
03/18/16 03:49 PM
Huntsville, AL
V
venom107 Offline
venom107  Offline
V
Huntsville, AL
Andy, I got my low deck TF intake in yesterday. Ordered last week. Still have a month or so wait on the heads, but the intakes are available.
Re: Trick Flow heads [Re: fast68plymouth] #2033937
03/18/16 05:29 PM
03/18/16 05:29 PM
AndyF Offline
AndyF  Offline
Cool deal, I'm going to check to see where mine is. Should be in the mail!
I also sent my Mopar intake to Wilson for porting and it is finished. So I'll be back on the dyno shortly for some intake testing. I have the MP as cast, the MP Wilson, a Victor 383 and the Trick Flow low deck. For carbs I have the 850DP, a 950DP, a 950 Dominator and a 1050 Dominator. So that is probably enough variables for a dyno session.
Re: Trick Flow heads [Re: fast68plymouth] #2034294
03/19/16 03:22 AM
03/19/16 03:22 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I'm curious about the ported m1, I noticed the other day the ports are pretty bad from one side of the intake to the other. I compared it to some edlebrocks and as much as people complain about them the eddys were much better.
I'm bummed out, when I received my tf heads I opened one box looked at it and put them on the shelf. Since my rods were backordered I couldn't do much. The other day I opened both to check gaskets on the intake ports and comparee to some intakes. One of my heads was damaged before packing. The boxes are perfect. I have to call and see what can be done.
Re: Trick Flow heads [Re: fast68plymouth] #2037413
03/23/16 09:23 PM
03/23/16 09:23 PM
AndyF Offline
AndyF  Offline
The M1 intake showed back up from Wilson. As usual they did a super nice job on the porting. The port match appears to be perfect from what I can see and feel.
Re: Trick Flow heads [Re: AndyF] #2037438
03/23/16 10:09 PM
03/23/16 10:09 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I would really like to see a video of those clear valve covers on a running engine.
Is this something that can stay on there all the time or just for testing or dyno work? Would they hold up on a street car?
Thanks for the input
Jerry
Old Geezer Racing
