Re: Starting from scratch which head?
[Re: Eric]
#2026446
03/07/16 01:42 PM
03/07/16 01:42 PM
fast68plymouth
So. Burlington, Vt.
Jim is correct......... If you're not going to reuse the current SR's and will be buying something new, I'd get -1's over SR's for that application. I'm not sure I'd go for the 345's or not on a 499. I'd probably do 325's with a 2.25 intake valve, along with a Jesel 1.7 rocker set-up.
[Re: Eric]
#2026477
03/07/16 02:33 PM
03/07/16 02:33 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I am changing my answer. I thought he was looking at switching from one to the other. But after looking at these threads and seeing that he is building an entirely NEW motor, new heads, new block and I assume new rods and pistons........I am falling back to my other answer. Why would you NOT build a B-1. The bare castings MIGHT cost you a bit more, depending on connections, but otherwise parts cost is a wash.
[Re: Monte_Smith]
#2026487
03/07/16 02:47 PM
03/07/16 02:47 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I am changing my answer. I thought he was looking at switching from one to the other. But after looking at these threads and seeing that he is building an entirely NEW motor, new heads, new block and I assume new rods and pistons........I am falling back to my other answer. Why would you NOT build a B-1. The bare castings MIGHT cost you a bit more, depending on connections, but otherwise parts cost is a wash. Rockers, headers and other stuff might be the issue Monte. Unfortunately this ...like all of my builds will be on a budget. I think in my case sticking with the SR's might be the best bet.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#2026523
03/07/16 03:29 PM
03/07/16 03:29 PM
Posts: 31,071 Oregon
AndyF
I am changing my answer. I thought he was looking at switching from one to the other. But after looking at these threads and seeing that he is building an entirely NEW motor, new heads, new block and I assume new rods and pistons........I am falling back to my other answer. Why would you NOT build a B-1. The bare castings MIGHT cost you a bit more, depending on connections, but otherwise parts cost is a wash. Rockers, headers and other stuff might be the issue Monte. Unfortunately this ...like all of my builds will be on a budget. I think in my case sticking with the SR's might be the best bet. The correct answer is usually at the intersection of your budget and how fast you want to go.
[Re: Eric]
#2026528
03/07/16 03:34 PM
03/07/16 03:34 PM
Posts: 2,677 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
A buddy of mine has some 572-13's laying around that he doesn't need. On heads like these do you have to run a very big cam with them to make it work?
2011 Drag Pak Challenger
[Re: WO23Coronet]
#2026620
03/07/16 05:35 PM
03/07/16 05:35 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Could you use the B1's and just not set them on kill? OU812 did a thread on some basically stock B1's (mild cleanup, valve job etc) that kept a reasonable port volume, but still flowed alot of air (380's?)that you wouldn't have to spin the day lights out of your 499 to make good power. That way when you get your aftermarket block you can set them on kill at that time. Edit: here's the link https://board.moparts.org/ubbthreads/ubbthreads.php/topics/105599/1.html I own the B1's you speak of and I chose to put a new set of indy -1 325 on my 512. My plan is an all aluminum 588 with the B1's eventually. However it is going to cost me close to what I paid for the -1 just to get the Jessel rockers fit correctly on the B1's. If budget is not an issue build a big one that can can utilize the big big runner and will run clean on the stop. If not stick with a smaller head and go out and kick some Chev 632 butt!!!!!! I don't know how Sheldon Gecker used to do it back in the day with the King Kong Daytona. It is my understanding he ran small cubes and big B1' Heads????? I bought my - 1's of Dwayne and he reused all of my valves and springs to save me a few bucks! Worked out great.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: 451Guy]
#2026645
03/07/16 06:20 PM
03/07/16 06:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I don't know how Sheldon Gecker used to do it back in the day with the King Kong Daytona. It is my understanding he ran small cubes and big B1' Heads????? [/quote] This is what I was gonna do with my B1 m/c heads.. I bought a new mega block Callies 4.15 crank and PC pistons for a 15:1 high rpm 514ci engine.. I was gonna run in the .900+ lift and put in a Daytona tube chassis car.. plus I was gonna spray it hard..I wanted to build a quick 16 car but then they changed the rules... but I sold it all off due to I couldnt get my NHRA license any longer
[Re: Eric]
#2026693
03/07/16 07:45 PM
03/07/16 07:45 PM
fast68plymouth
So. Burlington, Vt.
Are B1 heads currently "readily available"? Seems like at one point you kinda had to wait for the koffels November sale to happen to be able to get a set. Anyone know what the current price is for bare heads, the intake manifold, valley cover, and head studs?
My gut feeling is you're going to be into a B1 build for a couple grand more than a SR/MW build.
