Page 2 of 4 1 2 3 4
Re: 71 Roadrunner project [Re: jbojo] #2039166
03/26/16 02:35 PM
03/26/16 02:35 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Motor is done now.
Re: 71 Roadrunner project [Re: jbojo] #2057089
04/18/16 07:46 PM
04/18/16 07:46 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Does anyone have experience with the 10.9" clutch plates? From what I can tell they were 10.5" but Center Force and McLeod make 10.9" that are supposed to fit 10.5" flywheels. Any issues with the larger parts?
thx
Re: 71 Roadrunner project [Re: jbojo] #2083044
05/30/16 09:17 PM
05/30/16 09:17 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
In AZ picking up the car and looking at it for the first time really closely. The body is in really good condition with 100% of the sheetmetal present. No dings on front or rear bumpers and a few scrapes and dings to fix but nothing major. Here are the pics from today after I got the rotted tires off and some used ones on so that I can get it on the trailer.
[IMG]
http://i1297.photobucket.com/albums/ag33/John_Bojorquez/DSCN4228_zpspgo3kaef.jpg[/IMG]
Re: 71 Roadrunner project [Re: jbojo] #2083237
05/31/16 02:21 AM
05/31/16 02:21 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
The 10.95" scalloped clutch is indeed correct for you RR. It uses the 10.5" bolt pattern
Re: 71 Roadrunner project [Re: 70440+6bbl] #2093813
06/18/16 02:24 AM
06/18/16 02:24 AM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Just a quick update. Got the car up to WA. State to start my resto. At first site there only looked like surface rust but when I got the rear window off I got a surprise, Working on getting the car gutted and finding all the issues and then I'll start tackling all the major issues. The build sheet was totally disintegrated but the fender tag was there and in good shape.
Re: 71 Roadrunner project [Re: jbojo] #2093903
06/18/16 12:02 PM
06/18/16 12:02 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Cool RR, looks like a great starting point! Keep up the progress, looking forward to seeing this one come together!
Re: 71 Roadrunner project [Re: NV69B7RR] #2093934
06/18/16 01:59 PM
06/18/16 01:59 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Thx NV69B7RR
I got a small metal brake a couple of days ago to see if I could make replacement parts for the back window. Made a sample channel piece and it came out quite nice, when I make the final pieces I will replicate each section precisely and weld them on. I am going to put the car on a rotisserie and then start the repairs. Need to remove the drive train first and then all the fun begins.
Eastwood Versa Bend Brake
End View of sample peiece
Trial Fitment of piece
Re: 71 Roadrunner project [Re: jbojo] #2106674
07/09/16 02:30 AM
07/09/16 02:30 AM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Got that 360 and 727 out that the PO installed and started to fix some of the body work. First one is the right rear and then I am going to tackle the driver side door. The 4 sp tranny hump was also cut up so I am going to have to fix that as well as the other rusted out areas. Here are some pics.
Re: 71 Roadrunner project [Re: jbojo] #2107251
07/10/16 12:28 PM
07/10/16 12:28 PM
None
71rm23 Offline
71rm23  Offline
None
Looking good!
Re: 71 Roadrunner project [Re: 71rm23] #2108023
07/11/16 05:44 PM
07/11/16 05:44 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Got the dent pulled out of the drivers door. Used studs and a shrinking disk to do this repair. Some pics:
[IMG]
http://i1297.photobucket.com/albums/ag33/John_Bojorquez/IMG_1092_zpsxfp0rq9n.jpg[/IMG]
Re: 71 Roadrunner project [Re: jbojo] #2108714
07/12/16 02:09 PM
07/12/16 02:09 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Had a very similar dent in my door, good work.
Re: 71 Roadrunner project [Re: CDN72SE] #2108728
07/12/16 02:32 PM
07/12/16 02:32 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Thx, that one was pretty easy to do. The rear window area is the one that will require a lot of work. Waiting to get the car on the rotisserie before I start that job.
Re: 71 Roadrunner project [Re: jbojo] #2112629
07/18/16 06:40 PM
07/18/16 06:40 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Removed the front window and as expected there was rotted out areas although not as severe as the rear window. There are a total of 7 areas that I am going to have to address. Plans are to do all the welding repairs when I have it on the rotisserie. Next step is to start the dash and wiring removal. Some pics from today.
Re: 71 Roadrunner project [Re: jbojo] #2113488
07/19/16 07:19 PM
07/19/16 07:19 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Interesting side mirror
Originally Posted By jbojo
Was lucky enough to find a 71 Roadrunner V code car with a 4spd and Super Drag pac option. Just starting the restoration and hoping to use this forum to document the build and help finding needed parts. Its been sitting since 1990 in the AZ sun so the interior is pretty destroyed. Here is a link to a few pics.
http://s1297.photobucket.com/user/John_Bojorquez/media/100_0131_zpsih9sjf2j.jpg.html
http://s1297.photobucket.com/user/John_Bojorquez/media/100_0133_zpsraletuka.jpg.html
http://s1297.photobucket.com/user/John_Bojorquez/media/100_0138_zpshnjb5u7x.jpg.html
Abe Lincoln
Re: 71 Roadrunner project [Re: dart4forte] #2113543
07/19/16 08:33 PM
07/19/16 08:33 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
I don't believe that the side mirror was original. It is supposed to be the chrome sport mirror.
Re: 71 Roadrunner project [Re: jbojo] #2113917
07/20/16 11:38 AM
07/20/16 11:38 AM
None
71rm23 Offline
71rm23  Offline
None
When you removed the front and or the rear glass, did you notice how the trim clips was orientated? I need to put mine in at some time and can't seem to remember how the clips was facing. I think I know but I definitely don't want to put them in wrong smile
Re: 71 Roadrunner project [Re: jbojo] #2113921
07/20/16 11:40 AM
07/20/16 11:40 AM
None
71rm23 Offline
71rm23  Offline
None
I've never seen that type on that year, only the sport type. Don't know if there was an interchangeable one that would fit
Re: 71 Roadrunner project [Re: jbojo] #2114555
07/21/16 05:15 AM
07/21/16 05:15 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
Thats an aftermarket 'jc whitney' type mirror
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 71 Roadrunner project [Re: mopars_1] #2114892
07/21/16 03:53 PM
07/21/16 03:53 PM
WA
jbojo Offline OP
jbojo  Offline OP
WA
Yeah, I didn't think it was original. This is what the fender tag says:
G33 Left Hand Outside Mirror - Manual / Chrome
Re: 71 Roadrunner project [Re: jbojo] #2115332
07/22/16 05:53 AM
07/22/16 05:53 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
Should be like this then
1937 Plymouth PT50
Page 2 of 4 1 2 3 4
