Re: O/2 sensor location,where is the sweet spot??????? [Re: hemi-itis] #2024777
03/05/16 12:22 AM
03/05/16 12:22 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Grounds are critical to these sensors telling you the truth.
All ground locations are not created equal so if the mfg instructions say ground to a specific location, just do it. If the ground potential for the controller is different than the sensor you get a ground differential and a false reading.
Just to verify, zero leaks upstream of the sensor ie header flange gaskets and no pan evac?
Kevin
Re: O/2 sensor location,where is the sweet spot??????? [Re: hemi-itis] #2024794
03/05/16 01:10 AM
03/05/16 01:10 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
This is great Info I am having the same problem woth my fast xfi system and mostly at idle.
Subscribe
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: O/2 sensor location,where is the sweet spot??????? [Re: hemi-itis] #2024811
03/05/16 01:50 AM
03/05/16 01:50 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Here is an interesting check of the O2...
http://www.yellowbullet.com/forum/showthread.php?t=1275090
1654.5 Mustang
1955 Land Rover
Re: O/2 sensor location,where is the sweet spot??????? [Re: Kam*Kuda] #2024813
03/05/16 01:53 AM
03/05/16 01:53 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Subscribe
You shouldn't put too much stock in AFR readings at idle, especially with a lumpy cam. You set it so the engine is happy and the AFR is what it is.
With a cam with a lot of overlap you get a lot of random misfires or half fires at idle and all the oxygen that doesn't get used parades past the O2 sensor and you get a lean reading when in fact it could be/likely is pig rich.
Kevin
Re: O/2 sensor location,where is the sweet spot??????? [Re: hemi-itis] #2048916
04/07/16 04:06 PM
04/07/16 04:06 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Somewhat related. Anyone using WRO2 in conjunction with crankcase evac?
How close can the evac lines get to the sensor before it may effect readings?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: O/2 sensor location,where is the sweet spot??????? [Re: OUTLAWD] #2048923
04/07/16 04:17 PM
04/07/16 04:17 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i know you need to have the o2 sensor up stream from the evac.
Re: O/2 sensor location,where is the sweet spot??????? [Re: hemi-itis] #2048991
04/07/16 05:17 PM
04/07/16 05:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
10 or 2 o clock
No leaks up stream
Re: O/2 sensor location,where is the sweet spot??????? [Re: FastmOp] #2049016
04/07/16 05:53 PM
04/07/16 05:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yep thats the recommended . i had mine at 9 oclock.
Re: O/2 sensor location,where is the sweet spot??????? [Re: hemi-itis] #2049061
04/07/16 06:30 PM
04/07/16 06:30 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
on a straight pipe 9/3, never on the inside of a curve section..
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: O/2 sensor location,where is the sweet spot??????? [Re: OUTLAWD] #2049073
04/07/16 06:39 PM
04/07/16 06:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A couple of inches is plenty as long as the O2
is up stream.. I have been a little closer without
any issue.. big overlap cams pulse a lot at idle
wave
Re: O/2 sensor location,where is the sweet spot??????? [Re: hemi-itis] #2049506
04/08/16 09:39 AM
04/08/16 09:39 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
It's downstream, but I was worried about pulses. I got it sorted last night. Getting close to firing the EFI up if it would stop snowing...
