Re: Aluminum main caps or Billet with a girdle? [Re: Monte_Smith] #2025286
03/05/16 10:01 PM
03/05/16 10:01 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Originally Posted By Monte_Smith
Personally, I don't think a short, or even medium fill hurts cooling. These motors circulate little water at the bottom of the cylinders anyway. All the heat is at the top of the bore
iagree
I've been running a half fill on the 440 in my Roadrunner for 15 years. No issues to date.
72 Plymouth Roadrunner 11.08@123.25
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2025918
03/06/16 08:09 PM
03/06/16 08:09 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Spoke with Mike Janis yesterday and dropped off the block. I have main studs already and I'm going with an aluminum cap. Not sure on the fill yet. Going to try to make this one last so any cam change will be just to use the same grind if this one is damaged.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2026082
03/06/16 11:05 PM
03/06/16 11:05 PM
NC
440Jim Offline
440Jim  Offline
NC
I have lots of experience running aluminum main caps on stock BB Mopars. I like them if you want to run steel rods. If you are willing to run aluminum rods, then ductile or steel main caps are the way I would go.
I would still inspect aluminum caps for cracks at every rebuild/freshen-up. A very close look can catch a crack before it goes all the way through. And I even found cast iron caps cracked in half at an inspection before the block let go. Set an inspection interval (maybe 2 years or 500 passes?)
