Re: What 440 rear main seal do you recommend?
[Re: nd65]
#2024496
03/04/16 03:14 PM
03/04/16 03:14 PM
Thumperdart
State of confusion
I used the fel-pro that came w/my gasket set and slightly off set em w/a dab of silicone on the ends then install the sides dry. Then I fill the cavity on each side from top to bottom w/silicone on the outside of the retainer and let cure for a few days............
[Re: nd65]
#2024513
03/04/16 03:41 PM
03/04/16 03:41 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I covered in another thread on this issue, that I think seldom is the problem the crank OR the seal. It's the seal retainer. The retainer is just a cast and not precision machined piece. I have also seen some variance in the holes in the block for the retainer. If the bolts in any way, shape or form, pull the retainer to one side or cock it, you WILL have a leak and no seal or amount of silicone is going to fix it. The nicely machined aftermarket ones are great, provided the holes in the block are perfect.
During mockup, I always install crank, seal and then drop retainer on dry seal and seat it. Now look in the holes. If it looks like the bolt is going to influence the retainer in any direction, you WILL have a leak. So you try another retainer, or open the holes up. Now the next one I build may leak like a sieve, but I haven't had a big block rear main leak in years using this method. I also don't use the side seals, as they can push the retainer over. I use silicone. I also don't glue the seal in the block or cap. I put it in dry and clock the seal ends 90* from parting line on retainer
Chevy rear seals don't leak because the seal is contained in the rear cap and always properly located and clamped. The BBM seal arrangement looks like an after thought and often acts that way. Its the retainer
[Re: nd65]
#2024714
03/04/16 10:46 PM
03/04/16 10:46 PM
Monte_Smith
North Alabama
Usually Ultra-Black...........but if I am out, whatever I have........LOL!!!
Oil does not dissolve the RIGHT silicone. Cars come from the factory with silicone gaskets in some applications.
[Re: Monte_Smith]
#2024803
03/05/16 01:34 AM
03/05/16 01:34 AM
Posts: 8,354 fredericksburg,va
cudaman1969
fredericksburg,va
Oil does not dissolve the RIGHT silicone. Cars come from the factory with silicone gaskets in some applications. All silicone, some just resist it more. If in contact with oil or gas it's neopreme
[Re: nd65]
#2024841
03/05/16 02:34 AM
03/05/16 02:34 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I think some people are thinking silicone that is used to seal your house cracks. Were talking about automotive gasket adhesive or gasket maker.
