Front tire diameter for drag racing #2020829
02/27/16 05:06 PM
02/27/16 05:06 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Front tire diameter, is it better to have a larger size front tire or a smaller for drag racing? Now I am not saying larger than the rear. I am talking about a 28" compared to a say 24". Smaller would be lighter.
Re: Front tire diameter for drag racing [Re: 68dodge] #2020861
02/27/16 06:42 PM
02/27/16 06:42 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the bigger the tire the more roll out you will have.
Re: Front tire diameter for drag racing [Re: 68dodge] #2020863
02/27/16 06:47 PM
02/27/16 06:47 PM
gregsdart Offline
gregsdart  Offline
Smaller tires let the car break the beam sooner, taller ones later. A SuperGas car trying to get the car to break the beams as fast as possible would use a short tire to help. If you foot brake race, you can tune the cars reaction time by using different size front tires. The taller tires slow it down (reaction time), but the actual ET will be reduced by the amount the larger tires add to the reaction time. What you gain or lose from reaction time, shows up on the ET slip.
Re: Front tire diameter for drag racing [Re: 68dodge] #2021106
02/28/16 02:59 AM
02/28/16 02:59 AM
New York, USA
Chargerfan68 Offline
New York, USA
I personally like the tallest tire because I can leave the front suspension as is with alot of stored energy, and at the same time, it puts a little more weight bias on the rear tires.
Re: Front tire diameter for drag racing [Re: 68dodge] #2021141
02/28/16 05:07 AM
02/28/16 05:07 AM
It depends on the class your running the car in shruggy
I like to get my cars in as deep as I can so I have less distant to run to the finish line work whistling grin AKA., use what you like thumbs
