Re: Front tire diameter for drag racing
[Re: 68dodge]
#2020861
02/27/16 06:42 PM
02/27/16 06:42 PM
dartman366
Mt. Vernon, Ohio
the bigger the tire the more roll out you will have.
[Re: 68dodge]
#2020863
02/27/16 06:47 PM
02/27/16 06:47 PM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Smaller tires let the car break the beam sooner, taller ones later. A SuperGas car trying to get the car to break the beams as fast as possible would use a short tire to help. If you foot brake race, you can tune the cars reaction time by using different size front tires. The taller tires slow it down (reaction time), but the actual ET will be reduced by the amount the larger tires add to the reaction time. What you gain or lose from reaction time, shows up on the ET slip.
[Re: 68dodge]
#2021106
02/28/16 02:59 AM
02/28/16 02:59 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I personally like the tallest tire because I can leave the front suspension as is with alot of stored energy, and at the same time, it puts a little more weight bias on the rear tires.
