Re: 440 block
[Re: racerx]
#2023196
03/02/16 03:12 PM
03/02/16 03:12 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
thats kinda what i thought.one guy thought he was doin me a big favor at 700 bucks,thats nuts.i found an old 70,s modle motor home with a 440 in it the guy said i could have it if i come take it out.sounds like a lot of work. yep......but if it's FREE it might worth the effort to grab it. Plus isn't the motor home blocks suppose to have advantage as for as thicker casting or something ? No , there is nothing special about a motorhome block outside of extra cooling holes and there are only certain heads that have those extra holes, none of which are aftermarket.
Re: 440 block
[Re: Pacnorthcuda]
#2023202
03/02/16 03:18 PM
03/02/16 03:18 PM
JohnRR
U.S.S.A.
The HP stamp DOES denote a factory high performance engine. Nothing different about the block itself (other than the stamp) but it was assembled with different pistons/cam etc. An HP block was cast on day shift. An HP2 block was cast on swing shift. The HP was STAMPED during ASSEMBLY, it has nothing to do with casting. As far as different pistons and rods, depends on the year and the engine.
Re: 440 block
[Re: dogdays]
#2023285
03/02/16 05:01 PM
03/02/16 05:01 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
More BS here than in a feedlot! If it takes living in Detroit to get a $200 440 core, I'll pay the $500 and live somewhere else.
R. Living in Detroit is not for the weak!
Re: 440 block
[Re: JohnRR]
#2023470
03/02/16 10:38 PM
03/02/16 10:38 PM
Posts: 403 southern Maryland
keefe
southern Maryland
thats kinda what i thought.one guy thought he was doin me a big favor at 700 bucks,thats nuts.i found an old 70,s modle motor home with a 440 in it the guy said i could have it if i come take it out.sounds like a lot of work. yep......but if it's FREE it might worth the effort to grab it. Plus isn't the motor home blocks suppose to have advantage as for as thicker casting or something ? No , there is nothing special about a motorhome block outside of extra cooling holes and there are only certain heads that have those extra holes, none of which are aftermarket. I had a set of 452 heads from Paul Rossi Called Street fighter II... they were the motor home heads with the cooling holes, large valves, and a pocket port.. The cooling holes were to help with detonation.. they worked good for me back in the day..
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: 440 block
[Re: JohnRR]
#2023571
03/03/16 12:53 AM
03/03/16 12:53 AM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
The HP stamp DOES denote a factory high performance engine. Nothing different about the block itself (other than the stamp) but it was assembled with different pistons/cam etc. An HP block was cast on day shift. An HP2 block was cast on swing shift. The HP was STAMPED during ASSEMBLY, it has nothing to do with casting. As far as different pistons and rods, depends on the year and the engine. So John......what exactly (if anything) are you taking exception to in my post???
Re: 440 block
[Re: dogdays]
#2023917
03/03/16 04:58 PM
03/03/16 04:58 PM
Posts: 5,160 Texas
dannysbee
Texas
1. The 4006630 block is regular production from mid 1975 to end of production. NOT a heavy duty block.
2. The date cast into the side of the block is the date the block was cast.
3. The Engine ID pad on top front says everything about how the engine was assembled: Model year, usage, date of assembly, nonstandard parts, etc.
3. HP means the engine was assembled as a High Performance option engine.
4. The 1 or 2 behind the HP means ONLY that the engine was built on Shift 1 or Shift 2. As Shift 2 was the daytime shift it stands to reason that a lot of the Six Pack engines were built then, but that is a coincidence.
5. If it takes living in Detroit to get a $200 440 core, I'll pay the $500 and live somewhere else.
The 630 block does in fact have thicker webbing around the mains than the earlier blocks. Not as good as as a 400 block but better than the earlier 440 blocks. R.
Getting old just means you were smarter than some and luckier than others.
Re: 440 block
[Re: keefe]
#2023980
03/03/16 06:42 PM
03/03/16 06:42 PM
JohnRR
U.S.S.A.
I also had a set of those heads , bought them new , I had Dwayne Porter do some more porting to them after I sold them to a friend, the block I got him for his build also had the extra cooling holes in the deck so it saved me from adding them.
Re: 440 block
[Re: Pacnorthcuda]
#2023982
03/03/16 06:48 PM
03/03/16 06:48 PM
JohnRR
U.S.S.A.
The HP stamp DOES denote a factory high performance engine. Nothing different about the block itself (other than the stamp) but it was assembled with different pistons/cam etc. An HP block was cast on day shift. An HP2 block was cast on swing shift. The HP was STAMPED during ASSEMBLY, it has nothing to do with casting. As far as different pistons and rods, depends on the year and the engine. So John......what exactly (if anything) are you taking exception to in my post??? The part about an HP and HP2 being cast of specific shifts, maybe it was a typo on word usage because the foundry has no clue what any block will be used for during the casting process ?? As far as pistons only the 70-71 440-6pk had a different piston , the 350 and 375HP (and 69 440 6pk) 440's all used the same piston in the model year it was built. Just a clarification since there was some incorrect , and myth's , being thrown about in this thread ...
Re: 440 block
[Re: JohnRR]
#2024566
03/04/16 05:23 PM
03/04/16 05:23 PM
dogdays
I don't need someone to tell me the blocks are different. I never said they weren't.
But there were an erroneous statements:
"The best 440 block is from the early 70's NO It was from 1975 til the end!
most likely from a motorhome. NO it was the regular block found in pickups and New Yorkers and vans!
The number stamped on the side of the block is 4006630-440 that is the one with the thicker webs." WOW, finally got one right!
"An HP block was cast on day shift. An HP2 block was cast on swing shift." NO. The blocks have cast into them the casting date and I believe symbols that tell what time they were cast, but ANY block could turn into an HP, HP2 or whatever. Not like the Chevy world where the HP bigblocks will have "Hi Perf" cast into the block.
" Yes the 'HP2 means six pack, or at least six pack rods'" NO the 2 only means second shift. An HP engine is an HP engine, doesn't matter what shift it was assembled on. Whether the engine had the heavy rods or not depended on if it was an HP engine and what model year. So the 1969 HP engines did not have heavy rods, either 4 or 6 barrels, while the 1970 HP engines did have heavy rods, whether 4 or 6 barrels. Other 440s got heavy rods too but haphazardously.
Other nits to pick: While Model Year 1978 and 1979 440s are pretty common, I believe the actual block casting was finished in 1978.. I believe there were some Model Year 1980 440s as well but haven't seen one.
One correction to my earlier post: I got confused on work shift nomenclature. I apologize.
R.
Re: 440 block
[Re: JohnRR]
#2024584
03/04/16 06:00 PM
03/04/16 06:00 PM
Pacnorthcuda
The HP stamp DOES denote a factory high performance engine. Nothing different about the block itself (other than the stamp) but it was assembled with different pistons/cam etc. An HP block was cast on day shift. An HP2 block was cast on swing shift. The HP was STAMPED during ASSEMBLY, it has nothing to do with casting. As far as different pistons and rods, depends on the year and the engine. So John......what exactly (if anything) are you taking exception to in my post??? The part about an HP and HP2 being cast of specific shifts, maybe it was a typo on word usage because the foundry has no clue what any block will be used for during the casting process ?? As far as pistons only the 70-71 440-6pk had a different piston , the 350 and 375HP (and 69 440 6pk) 440's all used the same piston in the model year it was built. Just a clarification since there was some incorrect , and myth's , being thrown about in this thread ... True, I should not have said "Cast" An HP engine was ASSEMBLED on day shift. An HP2 on swing.
