using new hyd lifters on a solid cam, a question
#2019886
02/26/16 12:06 AM
02/26/16 12:06 AM
RapidRobert
360 SB, 571 lift MP circle track solid cam. On mockup My p rods are ~1/4" too short & I am searching for options rather than spring for a set of new Smith bros items. Can I use hyd lifters (new of course) which I already have on hand and lock everything downward from the cup rock solid as the higher cup is gonna be about dead on perfect. Anyone see any flaws with that idea (plan!). thank you for your time. EDIT Cam is new and if I dont tube the galleries (pass one/block crossover to dr side) I would drill/tap/setscrew block the lifter oil feed hole to keep psi from hitting it from underneath
Re: using new hyd lifters on a solid cam, a question
[Re: RapidRobert]
#2020012
02/26/16 04:40 AM
02/26/16 04:40 AM
Posts: 43,332 Bend,OR USA
Cab_Burge
You need to remember the lobes on the solid cam are designed for valve lash, I do know a local SCCA SB Chevy engine builder that used a set of solids on a hydralic lobe cam with the lash set at .002 hot. That combination won the west coast SCCA class championship several years back ![work work](/ubbthreads/images/graemlins/custom/work.gif) On your deal IF you decide to try and do that maybe try from .002 to maybe 1/8 turn prelaod hot, maybe not. I wouldn't try that unless it was my only option ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Buy the new pushrods and do it correct ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: RapidRobert]
#2020024
02/26/16 06:28 AM
02/26/16 06:28 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
As Cab pointed out there's been some chebby guys that have gotten away with it in certain circumstances. I've looked at this possibility, by coincidence this past week. Seems the unknown is the ramp. Some solids pop the lifter up and then the ramp slows. the transition could---could cause a give in how smooth the lifter rides and if lash gets outta hand the hyd lifter tends to quickly hammer the cam, apparently, sometimes into pieces. BTW I noticed that rhoads lifters has a new v pro (hyd) they claim can be used on a solid. Not sure how they can make that statement? Especially since their lifters are bleed type. that would make the possibility for disaster even more likely IMHO. Bottom line, it's possible but so is failure. Is this build alright to be a Guinea pig?
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#2020162
02/26/16 01:38 PM
02/26/16 01:38 PM
RapidRobert
OK to clarify, it is a new solid cam and new hyd lifters and I am considering blocking the hyd lifters in effect making them solids. everything else would be the same, same dia/new cam/new lifters/solid lash setting. I just need the cup to be higher up. Sound OK so far? EDIT I could use the solids & block its' cup higher but there is no snap ring to secure it up higher. I could JB weld it but I dont know if that would be secure enough and I could drill/tap (2) holes in thru the lifter body on the outside & lock the cup with (2) horizontle setscrews just like the snap ring does but that is alot of work & I have the new set of hyd's on hand so that got me thinking. I cant see an issue if I lock everything under the cup solid but I might be missing something here & 10K Mopar heads are better than one
[Re: RapidRobert]
#2020211
02/26/16 02:30 PM
02/26/16 02:30 PM
Posts: 1,560 Michigan
Kiddart
FWIW,
I am not the smartest guy buy would save my pennies and buy the correct parts in this case. I would hate to see this in the "Ask Me How I Know" Thread
Thank you Kiddart
[Re: 3csalvage]
#2020217
02/26/16 02:37 PM
02/26/16 02:37 PM
RapidRobert
I do have new solids to go with this new solid cam but the pushrod cup is too low for my pushrods. I could just purchase the correct p rods but I'm thinking of just makeing a hyd one (with the higher cup) into a solid (my new extra set of hyd ones). everything would be the same, I'm just locking the cup solid in a higher position unless I am missing something & I do that on occaision. I'm trying to slow down the flow of money if I (appropriately) can.
[Re: RapidRobert]
#2020301
02/26/16 04:36 PM
02/26/16 04:36 PM
Posts: 5,168 CT
GTX MATT
CT
Sounds kind of goofy to me, I bought a set of the strongest, thickest wall 5/16 ball and cup rods Smith Bros had (good for 700 lbs apparently) and they were $210 out the door. Realistically you can get a set for $125, .049 wall which they say is good for up to 400 lbs.
[Re: 3csalvage]
#2020512
02/27/16 12:09 AM
02/27/16 12:09 AM
RapidRobert
Alright, thanks guys for the multiple thoughts/feedback/caveats/predictions! I will check on the foot radius with the cam mfr's & see what they say. Then I will make a decision (& post later on how it went)
[Re: TooMany62s]
#2020682
02/27/16 12:36 PM
02/27/16 12:36 PM
RapidRobert
62 that is amazing as I was thinking that same Clint Eastwood phrase last night! (regarding this deal). Unless a Monday ph call to a cam mfr tells me that the foot radius is different and a no go then I am going to go ahead with my plan. If I appropriately/securely raise/lock the cup in place the "converted" hyd lifter is going to be functionally and dimentionally the same as a solid (same cup height, everything). racing starts in April so I will know something then if there is a problem if not sooner upon breakin & I will holler & 'fess up if it fubars. thanks again guys!
[Re: RapidRobert]
#2020745
02/27/16 02:26 PM
02/27/16 02:26 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Every time this is asked - discussed - beat to death - people seem to focus on the possible differences in the ramps, but here's a thought - if the angle (taper) that the cam is ground on and the lifter face are the same between the two lifter styles, and I believe they are - what difference could any difference in the ramp possibly make? The contact pattern on any given cam is going to be the same no matter what style lifter you use. If I did this, I would run it with about .020-.030 preload - running it with lash would be more likely to knock the retainer clips out of the lifters. IMO you may have more of an issue with the higher spring pressures trying to collapse the lifter than damage from any ramp difference issues.
Granted, this is usually done the other direction - running solids on a hyd cam, to eliminate lifters bleeding down - but I've never heard of an issue from the contact patch being different.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#2020844
02/27/16 05:57 PM
02/27/16 05:57 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Robert...Could it be that maybe the rules also state a hyd cam only? I have done what your looking to do but for the reason stated above. I can't offer any info on doing it in a Dodge as mine was on a sbc... ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
...FAFO...
[Re: skicker]
#2020848
02/27/16 06:04 PM
02/27/16 06:04 PM
skicker
"The Champ"
"The Champ"
Western Md.
Man after I get to thinking about it are you running an open class and using a 4 bbl? That's a ton of camshaft to use with a 2 bbl... Seems to me it will make it very lazy off the bottom especially if your running a bullring. Might want to load it up with gear for a cam that big... ![work work](/ubbthreads/images/graemlins/custom/work.gif)
...FAFO...
[Re: RapidRobert]
#2020857
02/27/16 06:37 PM
02/27/16 06:37 PM
Posts: 701 Northern California
lilcuda
Northern California
A picture is worth a thousand words.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
